02-13-2017 11:10 AM - edited 03-08-2019 09:19 AM
Hello, I have a Cisco 1921 with two physical L3 interfaces. Both of these have sub-interfaces in the same VLAN connected to switches either side.
If I establish a sub-interface Gi0/0.2 and want that layer 2 traffic for VLAN 2 to pass through to Gi0/1.2, how do I do it ?
Thank you kindly for any help.
So what I want is to transparently pass layer 2 traffic (same VLAN) between two L3 ports on the 1921 router.
Would a BVI interface do this ? (intergrated bridging and routing)
Solved! Go to Solution.
02-13-2017 11:51 AM
Let me provide you an example:
Router
interface Fa0/0
no ip address
interface Fa0/0.2
encapsulation dot1Q 2
bridge-group 2
interface Fa0/1
no ip address
interface Fa0/1.2
bridge-group 2
interface BVI2
ip address 10.10.2.1 255.255.255.0
bridge irb
bridge 2 protocol ieee
bridge 2 route ip
Switch 1
Interface f1/0/1
switchport mode trunk
vlan 2
interface Vlan2
ip address 10.10.2.2 255.255.255.0
end
Switch#ping 10.10.2.3
Sending 5, 100-byte ICMP Echos to 10.10.2.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Switch 2
Interface f1/0/1
vlan 2
interface Vlan2
ip address 10.10.2.3 255.255.255.0
end
Switch2#ping
*Feb 13 13:06:47.111: %SYS-5-CONFIG_I: Configured from console by console
Switch2#ping 10.10.2.1
Sending 5, 100-byte ICMP Echos to 10.10.2.1, timeout is 2 seconds:
Switch2#ping 10.10.2.2
Sending 5, 100-byte ICMP Echos to 10.10.2.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Switch2#ping 10.10.2.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/5/5 ms
Switch2#
02-13-2017 11:29 AM
You cannot have 2 ip addresses of the same subnet configured on the same router, it will overlap from each other. Are these vlan 2 configured on isolated switches or infrastructure?
Could you please provide more details?
02-13-2017 11:35 AM
Yes, these two VLANs are configured on separate switches. I want to transparently bridge them through an L3 1921 router in the middle.
Is there any way to do this ?
I was thinking perhaps by using an interface BVI ?
02-13-2017 11:46 AM
Yeap, BVI could be
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
But these 2- Vlan2 are using the same subnet?
02-13-2017 11:51 AM
Router
interface Fa0/0
no ip address
interface Fa0/0.2
bridge-group 2
interface Fa0/1
no ip address
interface Fa0/1.2
bridge-group 2
interface BVI2
bridge irb
bridge 2 route ip
Switch 1
Interface f1/0/1
vlan 2
interface Vlan2
end
Switch 2
Interface f1/0/1
vlan 2
interface Vlan2
end
Switch2#ping
Switch2#
