passive-interface Loopback0 on OPSF
solemdoms5
I thought the I/F that passive-interface is configured do not send their routing update to other routers .
If the routing protocol was OSPF(and EIGRP) , the I/F dont send HELLO packet too .so the neighboring relationship would be dead
This is my understanding of passive-interface .
but In my labo (GNS3), Routers know the network that passive-interface is configured.
I just want to know why is that ?
Is my understanding wrong ?
Here is configuration :
R4
interface Loopback0
ip address 172.16.255.4 255.255.255.255  ●
router ospf 1
log-adjacency-changes
passive-interface Loopback0   ●
R5#sh ip route ospf
     172.16.0.0/16 is variably subnetted, 8 subnets, 5 masks
O       172.16.255.2/32 [110/2] via 172.16.2.2, 00:19:58, FastEthernet0/0
O       172.16.255.1/32 [110/66] via 172.16.2.2, 00:19:58, FastEthernet0/0
O       172.16.255.4/32 [110/130] via 172.16.2.2, 00:19:58, FastEthernet0/0 ●
O       172.16.1.0/26 [110/66] via 172.16.2.2, 00:19:58, FastEthernet0/0
O       172.16.1.124/30 [110/129] via 172.16.2.2, 00:19:58, FastEthernet0/0
O       172.16.100.0/29 [110/65] via 172.16.2.2, 00:19:58, FastEthernet0/0
Please refer to the topology map attached .
Regards.
14 Replies 14
Abzal
Level 11
Level 11
Passive interface means that it will not send hello messages to neighbor. But you can be advertising this subnet.
Can you post the output
On R4:
sh run | sec router ospf
On R5:
sh ip ospf network 172.16.255.4
Hope it will help.
Best regards,
Abzal
Thank you for reply .
On R4:
Is this correct command ? it doesnt work in my labo.
you mean neighbor ?if so , there is blank .
R5#sh ip ospf neighbor 172.16.255.4
R5#
Regards .
Ok, I see
Then show output
On R4:
sh run
On R5:
sh ip ospf database
Abzal
Best regards,
Abzal
Here you are .
R4#sh run
Building configuration...
Current configuration : 1539 bytes
version 12.3
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip domain name lab.local
ip audit po max-events 100
interface Loopback0
interface Loopback1
ip address 172.16.1.193 255.255.255.252
interface Loopback2
ip address 172.16.1.225 255.255.255.224
interface Loopback100
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 172.16.1.126 255.255.255.252
encapsulation ppp
serial restart-delay 0
clock rate 128000
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router ospf 1
passive-interface FastEthernet0/0
network 172.16.1.124 0.0.0.3 area 0
network 172.16.1.160 0.0.0.31 area 0
network 172.16.255.4 0.0.0.0 area 0
no ip http server
no ip http secure-server
ip classless
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
R5#sh ip ospf database
            OSPF Router with ID (172.16.255.5) (Process ID 1)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
172.16.255.1    172.16.255.1    412         0x80000007 0x0046B7 5
172.16.255.2    172.16.255.2    196         0x80000008 0x00E9DE 3
172.16.255.3    172.16.255.3    369         0x80000008 0x00CFC4 3
172.16.255.4    172.16.255.4    106         0x80000005 0x001CFF 3
172.16.255.5    172.16.255.5    35          0x80000006 0x0088CA 2
                Net Link States (Area 0)
172.16.2.2      172.16.255.2    196         0x80000005 0x004E07
172.16.100.1    172.16.255.1    412         0x80000006 0x00DB40
Here is you can see altough it is passive interface you are still advertising it. With passive-interface prevents from forming neighborship only, but you still can advertise it.
interface Loopback0
router ospf 1
https://supportforums.cisco.com/docs/DOC-24683
Hope it will help.
Best regards,
Abzal
thank you for reply
Yes. I knew that. but If there is no hello packet. the neighboring relation is dead isnt it ?
I thought if the neighboring relation was dead , they do not advertise their route any more.
hence the routing table would be refresh . and the route would be delete
(In this case ,
on R5 ,O       172.16.255.4/32 [110/130] via 172.16.2.2, 00:19:58, FastEthernet0/0 ●
would be deleted .)
Is this wrong ?
Yes, you are right but it is not your situation. Here is you can simple check it by yourself, if make s1/0 passive interface, neighborship will be dead and all R4 advertising subnets will be deleted from routing table of neighbor (R5).
R4:
interface Serial1/0
encapsulation ppp
clock rate 128000
router ospf 1
passive-interface s1/0
Abzal
Best regards,
Abzal
I see
then Could you tell me
In this case ,How does passive-interface loopback0  work ?
Refer these links, I hope it might help you to understand
https://supportforums.cisco.com/thread/202928
http://blog.ioshints.info/2009/07/when-passive-interface-command-is.html
Hope it will help.
Best regards,
Abzal
Abzal thank you for your reply .
I have read two links you give me .
one said that this is caused by IOS feature-set .and the problem has already resolved .
and another is the post 5 years old ago .
Do you think the problem in my situation is caused by IOS feature-set ?
On R4:
On R5:
also what do these command mean ?
could you give me command reference or explanation of this ?
Thank you .
Reza Sharifi
Passive interface command doesn't prevent you from advertising the routes.  It just will not send any packets (hello packet for example) using that interface.
HI
(In this case ,
on R5 ,
would be deleted .)
Is this wrong ?
Hi Solemdoms,
What my understanding is - the network command works differently with Eigrp and Ospf than it works on BGP.
In BGP route is being advertised by network command.
But in Eigrp or OSPF when you apply network command, it enables the respective protocol on the interfaces which includes the covers the subnet on which it is applied.
Hence in this case you have applied the network command exactly on the loopback0 interface, it overrides the passive-interface loopback 0 command.
That could be the reason for this kind of output.
Let me know if any further confusion.
Kalpesh Modi
Hello kalpeshnmodi , thank you for your reply .
I see , however Do you have any document  verified ?
I have never heard that .
If you have it , Coud you give me the URL or the name of book .
Regards .
