Passive Optical LAN
KristienKramer
There have been some discussions lately about moving over to Motorola's Passive Optical LAN solution.  Has anyone looked into this or dealt with this before?  I have read a report touting the POL design over traditional three-tier architechture, but it was sponsored by Motorola, sooo...
I would really like to hear (and see) what Cisco has to say about the design and what their other options for this are.
Leo Laohoo
Errr ... I'm no expert regarding Motorola's products but this POL smells more or less like fibre optic backbone and switches that are capable of fibre optic backbone/uplinks and copper to the desktop.
Now if this is the case then alot of the network providers have been doing this since 2000.
You can start by looking into the Cisco Catalyst WS-C3750X-12S or WS-C3750X-24S for a fibre switch.  Upstream switches can be anything you want as all Cisco Catalyst switches will support fibre optic uplink or backbones.
(I know of some government agencies that have fibre to the desktop and I'll tell that the cost to set this one up is HUGE.)
krete590
The Motorola POL is more than just a fiber backbone, it uses fiber to provide a point to multi-point to provide an passive workgroup switch environment.  It works by having a fiber aggregation switch that replaces the distribution switch, and connect to Optical Network Terminals at the desktop.  You replace your IDF with passive fiber switches (1 x 32) that don't need power or cooling so it frees up your IDFs.  It uses single mode fiber for the internal wiring instead of copper, so it has a longer lifetime than copper.  To go from 1Gb to 10GB you will need to replace your cable infrastructure, the single mode fiber is rated for over 25 Tb and will not need to be replaced for a number of bandwidth upgrades.
The POL is a layer 2 access solution, and does not take the place of the core.  It has inherent QoS as well as being designed to distribute Voice, Data, and Video over a common cable infrastructure (single-mode fiber) so it decreases the weight of the cabling infrastructure greatly.  It is also a green technology since it rids the need for HVAC and Power in multiple IDFs since the signle mode fiber is split passivly, and it can run 20 Km as apposed to 100 M for copper.
What is the performance like on the aggregate switch?  What is the performance like on the Optical Network Terminals?  Has anyone used this or seen it in production?
This is a 1gig LAN solution. The network terminals have 1 gig interfaces. The aggregation switch has a 200 gig back plane and 56 PON ports delivering 2.4 gig southbound and 1.2 gig northbound. It is currently deployed in several enterprise, healthcare, and university settings. One chassis can support over 7000 Ethernet ports of distances up to 12 miles.
