Password Recovery - AAAA-3-INVSTATE: unknown AUTHOR/CMD
whiteford
I have bought a second hand Cisco 2620. I have managed to run through the password recovery procedure, however whenever I try anything the below happens:
tdi-adve-manche-s0002#sh run
Command authorization failed.
Router#
*Mar 1 00:25:26: %AAAA-3-INVSTATE: unknown AUTHOR/CMD: Internal state is invalid: astruct 0x81127D98 ustruct 0x0
-Traceback= 802ED784 802ED69C 803372D8 803384B4 803466D8 803C97BC
Router#
What can I do?
chriswill
Your start-up config may be intentionally corrupt. Try and see if another file exists in NVRAM .
See the following url :www.examnotes.net/archive31-2002-4-34215.html
Hope this helps
Chris
Giuseppe Larosa
Hello Andy,
use the password recovery procedure again and remove all AAA commands it looks like it was configured for AAA to ask to a server if you have rights to execute a command or not.
do
no aaa new-model
and remove all commands that start with AAA or even better erase the config instead of importing it.
Hope to help
Giuseppe
