PAT translation issues [Help]
Having issues on a system I am using for class its a 2 client 2 router a switch and a web server system. right now im trying to configure PAT on router 1 and then from client 1 ping a serial port on  router 2 through router 1. the ping is successful but i need a picture of router one preforming the show ip nat translations command. Im getting 0 nat translations after pinging router 2 from client 1.
r1 show run and network diagram below
thank you, Adam
Current configuration : 1626 bytes
! Last configuration change at 23:35:20 UTC Wed Nov 14 2018
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Router1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
subscriber templating
license udi pid ISR4331/K9 sn FDO21102FB5
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
ip address 172.16.10.1 255.255.255.0
ip nat inside
negotiation auto
interface Serial0/2/0
ip address 205.186.162.241 255.255.255.248
ip nat outside
interface Serial0/2/1
no ip address
shutdown
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat pool adam-pool 205.186.162.241 205.186.162.241 netmask 255.255.255.248
ip nat inside source list 1 pool adam-pool overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
access-list 1 permit 172.16.10.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Deepak Kumar
As you saying that ping is working so I am hoping that NATing is working fine becuase I didn't find any issue with configuration. As you are trying with ICMP and you are taking some time to switch windows or run a command on the router and it may be expired.
Please check the output:
Router#sho ip nat statistics
Total translations: 0 (0 static, 0 dynamic, 0 extended)
Outside Interfaces: Serial0/1/0
Inside Interfaces: GigabitEthernet0/0/0
Hits: 4 Misses: 4
Expired translations: 4
Dynamic mappings:
-- Inside Source
access-list 1 pool test refCount 0
pool test: netmask 255.255.255.252
start 172.16.16.1 end 172.16.16.1
type generic, total addresses 1 , allocated 0 (0%), misses 0
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Francesco Molino
The config looks good.
You can test by removing your nat and use the following command:
ip nat inside source list 1 interface s0/2/0 overload
As you are natting on same IP as your interface you don't need the pool.
If ping works, can you run debug ip icmp on router 2 and see what ip is coming.
Also paste the output of show ip nat translation please.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
