PBR and MQC implemented together
Essam Ahmad
Dears,
I need to apply changes to our production network, but I need to fully recognize the impacts for these changes before implementation, briefly we have MQC applied on interface Gi 0/0 and we need to add PBR on the same interface, what are the pre-cautions and conflicts that may happen? and how do PBR rules work with MQC together?
You'll find here below the current configuration (not bold) and the changes which should be applied (bold)
class-map match-any copy
match access-group 150 access-list
class-map match-any icmp
match protocol icmp
class-map match-any http
match protocol secure-http
match protocol http
match protocol telnet
match protocol dns
match protocol smtp
match protocol pop3
match protocol imap
policy-map IMPORTANT
class http
    bandwidth percent 50
class icmp
    priority percent 15
class copy
   police cir 18000000 bc 625000
     conform-action transmit
     exceed-action drop
interface GigabitEthernet0/0
description CONNECTED-TO-LAN
bandwidth 45000
ip address 172.55.20.254 255.255.0.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip route-cache same-interface
duplex auto
speed auto
no mop enabled
service-policy output IMPORTANT
ip policy route-map DATA_TRAN_MAP
route-map DATA_TRAN_MAP permit 10
match ip address FTP_ACL
set ip next-hop 172.16.55.50
set ip next-hop verify-availability
ip access-list extended FTP_ACL
permit tcp 172.55.0.0 0.0.255.255 192.168.100.0 0.0.0.255 eq 445
permit tcp 172.55.0.0 0.0.255.255 192.168.100.0 0.0.0.255 eq ftp
permit tcp 172.55.0.0 0.0.255.255 192.168.100.0 0.0.0.255 eq ftp-data
permit icmp host 172.55.20.20 192.168.100.0 0.0.0.255
2 Accepted Solutions
John Blakley
I don't think you'll have a problem. PBR happens before queueing, so you'll hit the route map before it has to apply your qos policy. Once you apply it, just make sure that you're still getting hits on the policy afterwards.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
cadet alain
your MQC is applied outbound and your PBR is applied inbound and MQC is for LLQ and policing in your case while PBR is for overriding the routing table lookup for forwarding inbound traffic so these 2 features shouldn't interact and there should be no problem setting the PBR on the interface.
Alain
7 Replies 7
John Blakley
HTH,
John
Thanks a lot John.
cadet alain
Alain
Alain,
Out of curiosity as I haven't labbed this up, I noticed your answer of directional differentiation as opposed to order of operations. If the route-map is applied inbound and the mqc policy is applied inbound as well, what do you think the interaction would be in that case? I think I'm going to lab this up to see what happens.
**** Edit ****
I labbed it up and it does work fine in either direction on the same interface.
HTH,
John
Hi John,
as he is using LLQ the service-policy had to be applied outbound anyway so that's why I emphasized the direction vs the order of operation because queuing is an outbound process anyway.
Alain
Thanks...I wanted to make sure there wasn't something I was missing.
HTH,
John
Thanks a lot Cadet.
