PBR and SVI interface problem
arumugasamy
Level 8
Level 8
Team,
I'm facing the problem explained below to one of our customer
switch 6807 VSS Pair.
s2t54-adventerprisek9-mz.SPA.151-2.SY5.bin
VLAN 2 SVI 192.168.1.0/24
PBR to route some of the IPs to the next hop of different ISP.
Everything was working fine for long time but suddenly yesterday vlan 2 stop working and all the vlan 2 users lost the network access.
After removed the PBD (ip policy route-map) from the SVI interface, vlan 2 starts working. we applied then the PBR again expecting that the problem re-occur again but it is working. Customer wants report on it why after reapply the PBR vlan 2 is working.
Please give me your suggestions.
Georg Pauwen
I checked for bugs, the below is the only one I could find. What does your PBR look like, can you post the config ?
normal forwarding happens when config set ip next-hop under PBR
CSCva45619
Description
Symptom:
At C6807-XL (VS-SUP2T-10G) VSS running 15.1(2)SY7,normal forwarding happens when config set ip next-hop + ip address under PBR
Conditions:
set ip next-hop+ip address under PBR
Workaround:
add config of set interface + egress port
Further Problem Description:
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?(0)
Details
Last Modified:
Nov 14,2016
Status:
Open
Severity:
3 Moderate
Product: (1)
Cisco IOS
Support Cases:
Known Affected Releases: (1)
15.1(2)SY7.1
Dear
Thank you for your reply
I advised customer to upgrade to ver 15.1(2)SY9 which found no vulnerability under cisco.com/security
IOS checker
I send your response to customer.
Thx
Dear,
can you please update about the case?
Did the upgrade solve the issue?
im in version Version 15.2(1)SY6 and facing same issue for 6509 VSS
