PBR not working on CAT4510R
l.buschi
Level 2
Level 2
Hello everybody,
I have a problem with policy based routing. It seems it doesn't work.
Here is the configuration:
access-list 199 deny ip 172.27.42.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 199 permit ip 172.27.42.0 0.0.0.255 any
route-map PBE permit 10
match ip address 199
set ip next-hop 172.24.10.31
Int vlan 10
ip address 172.24.10.1 255.255.255.0
Int vlan 20
ip address 172.29.5.1 255.255.255.0
ip policy route-map PBE
ip route 0.0.0.0 0.0.0.0 172.24.10.100
ip route 172.27.42.0 255.255.255.0 172.29.5.100
What I need is that packet with source address 172.27.42.0/24 should be routed towards 172.24.10.31 for destination except from 172.16.0.0/12 destinations.
no match results in sh route-map
and packet ignores PBR.
I also tried to use a standard access-list such as access-list 1 permit 172.27.42.0 0.0.0.255 to route all traffic from 172.27.42 to 172.24.10.31 but it doesn't work.
Finally I also tried to use
set ip default next-hop 172.24.10.31 but i doesn't work again.
the 4500 IOS version is
cat4500e-entservicesk9-mz.122-44.SG.bin
I thank you very much if any could help me.
best
Johnny
Hello Johnny,
in recent releases support for PBR has been introduced
for example in 12.2(44)SE says:
PBR not supported on sup 6-E
on last release 12.2(53)SG says
Understanding PBR on Supervisor Engine 6-E
The Catalyst 4500 Supervisor Engine 6-E supports matching route-map actions with a packet by installing entries in the TCAM that match the set of packets described by the ACLs in the match criteria of the route map. These TCAM entries point at adjacencies that either perform the necessary output actions or forward the packet to software if either hardware does not support the action or its resources are exhausted.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/configuration/pbroute.html
you may need an IOS upgrade
Hope to help
Giuseppe
Giuseppe Larosa
Hello Johnny,
first of all what is the supervisor model that is on the chassis
you can post a sh module
It can make the difference some newer supervisors are weak in these features as reported by other colleagues
Hope to help
Giuseppe
Thank you giuseppe,
here is the show module
5 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E
6 6 Sup 6-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6-E
Hello Johnny,
see
Hope to help
Giuseppe
