PBR on a 3560-24TS-E
samwise_diver
Quick question.
Is it possible to do PBR on a 3560-24TS-E running
C3560-ADVIPSERVICESK ?
The sales documents say yes but the config documents do not say and the switch takes the command but does nothing with it no error but not working. I can build the route-map but when I try and apply it to the SVI is when it does nothing.
Edison Ortiz
See
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swiprout.htm#wp1228588
To use PBR, you must first enable the routing template by using the sdm prefer routing global configuration command. PBR is not supported with the VLAN or default template. For more information on the SDM templates, see Chapter 7, "Configuring SDM Templates."
That is perfect I was missing the global
sdm prefer routing
and a reboot. I should have thought back to my lab studying thanks for reminding me.
