Peer Terminate Remote Proxy N/A, Local Proxy N/A
Tim McNabb
I am having trouble with creating a tunnel between asa 9.1 and asa 7.2.
asa 9.1 config:
Result of the command: "show config"
: Saved
: Serial Number: JMX2032G019
: Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
: Written by enable_15 at 05:49:27.018 UTC Tue Nov 29 2016
ASA Version 9.1(6)
hostname BaldoneLaw
enable password hXbnaMrImSR115PM encrypted
passwd hXbnaMrImSR115PM encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.0.254.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 173.12.234.125 255.255.255.0
ftp mode passive
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network GW
host 173.12.234.126
object network 192.168.1.0
host 192.168.1.0
object network local_inside
subnet 10.0.254.0 255.255.255.0
object network inside
host 10.0.254.254
description Inside
object network NETWORK_OBJ_10.0.254.0_24
object network 10.0.254.0
object network CC
host 162.198.248.25
object network TS2012
host 10.0.254.4
object service TS
service tcp source eq 3389 destination eq 3389
access-list outside_cryptomap_2 extended permit ip object 10.0.254.0 object 192.168.1.0
access-list outside_access_in extended permit ip any any
access-list global_access extended permit ip any any
pager lines 24
logging enable
logging asdm debugging
logging class vpn trap emergencies asdm debugging
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static 10.0.254.0 10.0.254.0 destination static 192.168.1.0 192.168.1.0 no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
access-group outside_access_in in interface outside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 173.12.234.126 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.0.254.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev2 ipsec-proposal esp-3des-sha
protocol esp encryption 3des
protocol esp integrity null
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map 1 match address outside_cryptomap_2
crypto map outside_map 1 set peer 162.198.248.25
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256 esp-3des-sha
crypto map outside_map interface outside
crypto ca trustpool policy
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable inside
crypto ikev2 enable outside
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
no ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
management-access inside
dhcpd dns 8.8.8.8
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
group-policy GroupPolicy_162.198.248.25 internal
group-policy GroupPolicy_162.198.248.25 attributes
vpn-tunnel-protocol ikev1 ikev2
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
tunnel-group 162.198.248.25 type ipsec-l2l
tunnel-group 162.198.248.25 general-attributes
default-group-policy GroupPolicy_162.198.248.25
tunnel-group 162.198.248.25 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:835a30f5f57da6310862149c6f71d1e7
asa 7.2 config
: Written by enable_15 at 00:53:27.700 UTC Tue Nov 29 2016
ASA Version 7.2(4)
hostname Chateaucreole
domain-name default.domain.invalid
enable password d63bsBm4ik1yh.Nd encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 162.198.248.25 Outside
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address Outside 255.255.255.248
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
switchport access vlan 3
ftp mode passive
dns server-group DefaultDNS
object-group network net-local
network-object host 173.12.234.0
object-group icmp-type ICMP
icmp-object alternate-address
icmp-object conversion-error
icmp-object echo
icmp-object echo-reply
icmp-object information-reply
icmp-object information-request
icmp-object mask-reply
icmp-object mask-request
icmp-object mobile-redirect
icmp-object parameter-problem
icmp-object redirect
icmp-object router-advertisement
icmp-object router-solicitation
icmp-object source-quench
icmp-object time-exceeded
icmp-object timestamp-reply
icmp-object timestamp-request
icmp-object traceroute
icmp-object unreachable
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 10.0.254.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip host Outside host 173.12.234.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 10.0.254.0 255.255.255.0
access-list inside_access_in extended permit ip any any
pager lines 24
logging enable
logging class vpn trap critical asdm debugging
mtu inside 1500
mtu outside 1500
mtu dmz 1500
asdm image disk0:/asdm-524.bin
asdm location Outside 255.255.255.255 inside
asdm location 162.198.248.30 255.255.255.255 inside
asdm location 10.0.254.0 255.255.255.0 inside
asdm location 173.12.234.0 255.255.255.255 inside
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 162.198.248.30 1
http server enable
http 192.168.1.0 255.255.255.0 inside
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec security-association replay disable
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group5
crypto map outside_map 1 set peer 173.12.234.125
crypto map outside_map 1 set transform-set ESP-AES-256-SHA
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 2
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-256
hash md5
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
group-delimiter !
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.10-192.168.1.50 inside
dhcpd dns 4.4.4.4 8.8.8.8 interface inside
dhcpd enable inside
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec l2tp-ipsec webvpn
password-storage disable
ip-comp disable
re-xauth disable
group-lock none
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelall
split-tunnel-network-list none
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
functions url-entry
html-content-filter none
homepage none
keep-alive-ignore 4
http-comp gzip
filter none
url-list none
customization value DfltCustomization
port-forward none
port-forward-name value Application Access
sso-server none
deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information
svc none
svc keep-installer installed
svc keepalive none
svc rekey time none
svc rekey method none
svc dpd-interval client none
svc dpd-interval gateway none
svc compression deflate
username user1pinnacle password vY5gIYHIuOHakDav encrypted privilege 15
username Pinnacle password pQQk7IbYO5koi8kW encrypted privilege 15
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
tunnel-group 173.12.234.125 type ipsec-l2l
tunnel-group 173.12.234.125 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
no compression svc http-comp
Cryptochecksum:f84b6bfaea5ed551df8aa53e47a43e20
any help would be appreciated.
TIm
0 Replies 0
