Bookmark
Subscribe
676
Pelco Camera's Multicasting through asa
paul.miller11
Hi, I have been trying to configure an asa 5512-x to pass multicast traffic from an outside network to an inside network as per the document :
PIX/ASA 7.x : Multicast on the PIX/ASA Platforms with sender on Outside Configuration Example
Document ID : 71779
http://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/71779-pix-asa-multicast-outside.pdf
Here is the config :
: Saved
: Written by enable_15 at 23:30:10.378 UTC Tue Jul 5 2016
ASA Version 9.1(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
multicast-routing
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 172.17.1.254 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 192.168.0.100 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
shutdown
no nameif
no security-level
no ip address
pim rp-address 192.168.0.100
ftp mode passive
access-list outside_access_inbound extended permit ip any host 239.17.1.50
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mroute 172.17.1.50 255.255.255.255 outside
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group outside_access_inbound in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:a17cf9fbd0bc19666dc98984a2e04ac5
: end
the multicast group 239.17.1.50 is not being forwarded through the asa
I have looked at the relevant multicasting support documentation from cisco, however so far I have been unable to resolve the issue.
the only difference (apart from the ip addressing) is that the document 71779 specifies that cisco asa version 7.x code is running on the example but the asa I am using is version 9.x
Please can anyone help and assist with a resolution to this issue, is it the version of code ??? or am I missing something in the config ??
Thanking you in advance
Kind Regards
Paul
0 Replies 0
