Bookmark
Subscribe
3790
Per IP qos
josephschung
Dear Sir,
We have one web server connected to a port on 2960/3560 switch. There are two web sites on the server. Each wet site has his own IP. We want to configure qos and let web site 1 has 5M and web site 2 has 3M of bandwidth. Is it possible with service policy?
7 Replies 7
Mohamed Sobair
Level 7
Level 7
Yes its possible using Policing or Shaping, please look into the bellow (Policing) example:
lets assume website 1 has the ip address of 1.1.1.1
let assume  website 2 has the ip address of 2.2.2.2
class-map match-any website1
match access-group 100
class-map match-any website2
match access-group 101
access-list 100 permit ip host 1.1.1.1 any
access-list 101 permit ip host 2.2.2.2 any
policy-map website
class website1
police 5 Mbps
class website2
police 3 Mbps
interface X (outbound Interface)
service-policy output website
Mohamed
Edison Ortiz
No, it's not possible with a service-policy on the hardware that you have.
Policers are only supported on ingress
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swqos.html#wp1426834
If you want to limit egress bandwidth, your only option is srr-queue bandwidth limit
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/swqos.html#wp1253412
Edison
I see. If I want to control the out going web traffic only, Mohamed's example is good enough.
But for controlling traffic from both direction, we will need to user SRR. But, we have two IPs from the same interface. Can SRR be applied 5M and 3M to indivdual IP respectively? Do you have an example Edison?
Thanks.
As I stated, you can't police egress traffic on the hardware at hand - thus the example provided by Mohamed won't work.
You can police traffic on ingress with MQC as the switch supports such feature.
The documentation provides an example on how to implement bandwith limits with srr-queue bandwidth limit.
The limit is imposed globally on the port and can't be applied per-traffic class or flow.
http://www.cisco.com/en/US/partner/switches/lan/catalyst3750/software/release/12.2_50_se/command/reference/cli3.html#wp1947391
Hi guys,
Do you have any idea how I can achieve QoS per IP?
I have a router doing NAT for 192.168.0.0/24 and one ISP.
I want to police all the network members so no user would exceed 300KB/s or 2.4Mbps. From what I know:
class-map match-any LAN
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
policy-map local_lan
class LAN
police 2400000
interface Fa0/0 (local Interface)
service-policy input local_lan
Will this work per IP or it will limit ALL users up to 2.4 Mbps?
this will limit ALL users up to 2.4 Mbps
policy-map Shape
class class-default
  shape average 2400000
  random-detect
service-policy input Shape
yours too
and of course you can limit per user but you need access-list for each and class map for each
Hi mate,
Thanks for the input; hope I will be able to test this couple of weeks from now on real hardware.
