Performance Question - cisco WS-C6504-E
miceve
Community Member
Hello all,
i think about a backup infrstructure scenario. The "backup-server" should backup VMs from an ESX host in an ESX-NET Network and stores it to a storage in BACKUP-NET network.
We have a third network (in this example) - SERVER-NET network - for all general servers.
The SERVER-NET and ESX-NET are both directly routed on the core switch and no ACLs are defined deny'ing any kind of traffic flow (in this szenario)
QUESTION: Does it make much of a performance impact to put the backup server into a "SERVER-NET" where it needs to go over the CORE Switch "the Gateway of SERVER-NET" in order to access the ESX-NET. Or would it make more sense to put the backup server directly into the "ESX-NET" network. [I want to avoid that cause it is not the purpose of this network to have other systems than ESX Servers]
Thank you for your suggestions in advance!
BR Michelle
balaji.bandi
personally i would suggest Storage and backup in same VLAN where possible to increase the performance.
in your explanation i am bit confused, can you elaborate with VLAN or IP address so we can easily understand.
BB
miceve
Community Member
Backup-Server and Backup Storage are in the Same VLAN20 BACKUP-NET (192.168.22.0/24) (not routed at all directly connected through a switch). -> That is fix given. (The Backup-Server's first network interface is directly connected to that VLAN20)
The networks - routed by the CoreSwitch (Cisco 6500) are:
VLAN101 - SERVER-NET (10.0.1.0/24);
VLAN420 - ESX-NET (10.4.20.0/24)
An ESX Server 10.4.20.22 running VMs is in an ESX-NET  network.
To backup the VMs, the Backup-Server needs to connect to the ESX Server in "ESX-NET"
Question: in which network should i put the second network interface of the Backup-Server.
OptionA: Directly connect the second network interface of the Backup-Server to the VLAN 420 "ESX-NET"
OptionB(prefered): Put the second network interface of the Backup-Server into the VLAN101 "SERVER-NET" - to get to the ESX Server it has to go over the Default Gateway 10.0.1.1 (CoreSwitch) to get to the ESX Server 10.4.20.22.
FollowUpQuestion: Is it much of a performance difference between OptionB and Option A? (Option A is Layer 2 Switching; OptionB is Layer 3 Routing [but on a core switch though])
I hope this is a little bit clearer now. Thank you very much for that fast response.
Since VM has capabilities adding another Interface which is not routable, that interface and IP belowing to same backup vlan should be good. (is this works i belive you are in the same line of what i am thinking)
BB
miceve
Community Member
No the backup lan is not the issue. It is already decided that backup server and backup storage are on a same network. This is given.
-> The backup-server backups the VMs from the ESX and stores them on a backup storage in the backup network.
The question is how to connect Backup-Server AND  ESX Server - should i go Layer 2 via direct connection of the Backup-Server's second network interface to the ESX-NET
OR
Layer 3 in a separate network which needs to be routed on my core switch to get to the ESX Server in ESX-NET. I would prefer Layer 3 in a separate network (SERVER-NET) but fear of a performance issue on my core switch.
BR Michelle
