pFsense CARP using cisco switch
net.curious
Visitor
I am curious to find out why i face the following situation.
I have a customer who has two pfsense firwalls, and has set up CARP.
You know the configuration with the virtual IP, which stands for router redundancy.
From my side, i am using cisco catalyst.
Customer's two pfsense are connected on 2 different ports.
Every time Customer looses one of two routers, i am getting port security violation.
%PORT_SECURITY-SP-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0000.5e00.xxxx on port GigabitEthernet1/2
Config of two switchports
switchport
switchport access vlan xxx
switchport mode access
switchport port-security
switchport port-security maximum 700
switchport port-security aging time 120
switchport port-security violation restrict
switchport port-security aging type inactivity
no logging event link-status
storm-control broadcast level 10.00
no cdp enable
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
end
balaji.bandi
PfSense when the primary fails, the secondary take over with same MAC Address
So you see violation here because your switch already learned MAC address on a different port, now you getting same MAC address from a different port.
The solution is arp aging time out configure to resolve. or loose on the port security.
BB
