Physical int vs port channel
ahmad1982
in etherchannel config, which is better to apply commands such :
         Switchport tr na vl 1
         Switchport trunk encapsulation dot1q
         Switchport mode trunk
        Switchport tr allowed vl x,y
under port-channel or the physical interfaces? Or its the same? Or depends on the model?
thank you
ahmad
Reza Sharifi
Hi Ahmad,
Once you create a Portchannel, add the physical Interfaces to it and it is up and running, from that point you should add the configs to the Portchannel. Once you add the config to the Portchannel, the physical interfaces with inherit the config.
Reza Sharifi
Hi Ahmad,
ahmad1982
