Hello Udo,
The Bidir-PIM is intended to be used in many-to-many scenarios, i.e. when you have a multicast group of receivers, significant portion of which are also senders to the same multicast group. With PIM-SM, this would lead to creation of numerous distribution trees, from each source either to the RP or directly to receivers. Bidir-PIM alleviates this by making sure that a multicast group has only a single shared distribution tree, regardless of how many senders are in the group. Using the Bidir-PIM in situations where there are only a few senders to a particular multicast group is not particularly advantageous - the PIM-SM would behave just fine.
So the better choice here ultimately depends on the nature of your multicasting.
Best regards,
Peter
