STP problem
d.navetto
Hey guy! I need some help for my network LAN.
I have configurated some switch ( catalyst 3560 )access with the Fastethernet in access for Vlan 360. This Device is trunked with a Core ( caltalyst 6509)  layer, trunked itself with another distribution layer for the server farm ( caltalyst 6513). the VLan is native on the Cat 6513 who is its root spanning tree and it is forwarded trough the entire lan to the access switch. The client gets the IP address but it can't ping its gateway and it is totally out of the network.This Vlan is a Management Vlan and also the server have the same subnet. All the servers are ok and totally reachable by any another vlans. Btw if i put a client directly both on the core or the distribution layer it works perfectly.
Any suggestion ?
Hello David,
thanks for your feedback on this case.
It was an OSI layer2 issue, nothing related to the presence or absence of an SVI in vlan360 at cat6509 level of devices.
What have you done to fix?  the classic shut/no shut to trigger new negotiations and protocol exchanges on the affected port channel?
Best Regards
Giuseppe
20 Replies 20
m.glosson
This is a confusingly-worded question. You need to provide more information. Are you running PVST, Rapid PVST, MST? Please paste the output of "show run | i spanning-tree" from the 6513.
Matt
So in summary this 3560 is trunked to the core switch and any clients attached it cannot ping the default-gateway - is this correct?
Can you check if this switch has ip routing enabled and  if so disable it , Also add a default-gateway address pointing to the core
conf t
no ip routing
ip default-gateway x.x.x.x.x
Also could you post the running config of this switch.
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
d.navetto
it is very confusing! now I do not have the sh run but the catalyst works with the rapid and root for vlan with another 6513 which is the backup
d.navetto
no !!! the access switch(3560) work only L2.. 6509 routed the vlan to 6513
Hello david,
It is a bit difficult to establish exactly what is occurring with the information provided,
1) Regarding your stp setup
Are you saying the 3560 is the stp root and the core switch 6513 is acting as the secondary stp root?
2) Regarding you switch configuration
Are you saying any clients attached to this 3560 cannot ping their default-gateway?
  • Can you tell what the default-gateway ip address of your clients?
  • The management ip address of the 3560
  • The SVI address of the core switch relating to the management vlan?
  • Is ip routing enabled on the 3560
res
Paul
Kind Regards
Paul
ok ! i do a design for more understanding !
the Cat 3560 Ip default gateway x.x.x.x (only MNG) have two uplink (trunk) to core (one blocked)
The CAT6909-1
spanning-tree mode rapid-pvst
spanning-tree vlan 100,900 priority 8192
interface Vlan100
ip address 172.21.0.x 255.255.255.0
standby 1 ip 172.21.0.1
standby 1 priority 110
interface Vlan900
ip address 10.10.0.x 255.255.255.0
standby 2 ip 10.10.1.1
standby 2 priority 110
ip route to Vlan 360 nex hop 10.10.1.254
The CAT6913-1
spanning-tree vlan 360 priority 8192
interface Vlan360
ip address 172.21.36.x 255.255.255.0
standby 1 ip 172.21.36.1
interface Vlan900
standby 1 ip 10.10.1.254
ip route to Vlan 100 nex hop 10.10.1.1
the other CORE ( 6509-6513 ) it's a bck with the spanning tree work fine
This is a brief summary of the architecture, is much more complex
Hello David,
On the 3560 -
Sh ip route
show vlan brief
sh spanning-tree blockedports
sh span summary
sh int trunk
res
Paul
Kind Regards
Paul
sh ip ro
Default gateway is 172.21.0.1
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
SW#sh vlan brief
VLAN Name                             Status    Ports
1    VLAN1                                  active    Gi0/2, Gi0/3
2    VLAN2                                active    Fa0/29
101  VLAN101                                  active
225  VLAN225                                    active    Fa0/30, Fa0/47
231  VLAN231                              active
253  VLAN253                                   active    Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10,Fa0/11, Fa0/12, Fa0/14, Fa0/15, Fa0/16,        Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/23, Fa0/24,Fa0/25, Fa0/26, Fa0/27, Fa0/28, Fa0/29,                                                             Fa0/30, Fa0/31
                                                Fa0/32, Fa0/33, Fa0/34, Fa0/35, Fa0/37,Fa0/38, Fa0/39, Fa0/40, Fa0/41, Fa0/42,                                                             Fa0/45, Fa0/47
                                                Fa0/48
332  VLAN0332                         active    Fa0/14
333  VLAN0333                         active    Fa0/6, Fa0/7, Fa0/9, Fa0/10, Fa0/11, Fa0/12, Fa0/15, Fa0/16, Fa0/17, Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24, Fa0/25, Fa0/27, Fa0/28, Fa0/31, Fa0/32, Fa0/33, Fa0/34, Fa0/37, Fa0/38
                                                Fa0/39, Fa0/40, Fa0/41, Fa0/42, Fa0/44, Fa0/48
334  VLAN0334                         active    Fa0/13
348  VLAN0348                         active    Fa0/8
360  VLAN0360                         active    Fa0/26, Fa0/35, Fa0/36
368                                              active    Fa0/43
476  VLAN0476                                  active
492  VLAN0492                                  active
729                                             active    Fa0/5, Fa0/45, Fa0/46
900  VLAN900                           active
901  VLAN901                     active
902  TEST_SRST_NOC                    active
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
#sh spanning-tree blockedports
Name                 Blocked Interfaces List
VLAN0231             Gi0/4
VLAN0253             Gi0/4
VLAN0334             Gi0/4
VLAN0348             Gi0/4
VLAN0368             Gi0/4
VLAN0476             Gi0/4
VLAN0492             Gi0/4
Number of blocked ports (segments) in the system : 7
#sh spanning-tree summary
Switch is in rapid-pvst mode
Root bridge for: none
Extended system ID           is enabled
Portfast Default             is disabled
PortFast BPDU Guard Default  is enabled
Portfast BPDU Filter Default is disabled
Loopguard Default            is disabled
EtherChannel misconfig guard is enabled
UplinkFast                   is disabled
BackboneFast                 is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
VLAN0001                     0         0        0          1          1
VLAN0002                     0         0        0          4          4
VLAN0101                     0         0        0          3          3
VLAN0225                     0         0        0          4          4
VLAN0227                     0         0        0          1          1
VLAN0231                     1         0        0          1          2
VLAN0253                     1         0        0         18         19
VLAN0332                     0         0        0          4          4
VLAN0333                     0         0        0         14         14
VLAN0334                     1         0        0          2          3
VLAN0348                     1         0        0          2          3
VLAN0360                     0         0        0          4          4
VLAN0368                     1         0        0          1          2
VLAN0476                     1         0        0          2          3
VLAN0492                     1         0        0          2          3
VLAN0729                     0         0        0          4          4
VLAN0900                     0         0        0          1          1
VLAN0901                     0         0        0          1          1
VLAN0902                     0         0        0          3          3
sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Gi0/4       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       2,101,225,253,332-335,337,345,348,360,368,371,468,476,492,729,902
Gi0/4       1-4094
Port        Vlans allowed and active in management domain
Gi0/1       2,101,225,231,252-253,332-335,337,345,348,360,368,371,468,476,492,729,902
Gi0/4       1-2,8-9,11,18,22,26,30,44-45,50,90,101,200,222-223,225,227,231,234,250-263,268-270,301-352,358-360,363-364,368,371-374,389-390,468,476,492,499-500,554-559,729,900-902
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       2,101,225,231,252-253,332-335,337,345,348,360,368,371,476,492,729,902
Gi0/4       1,332
Hello David,
You have a default-gateway of 172.21.0.1 which puts this switch in vlan 100
I dont see layer 2 vlan 100 on this switch or allowed on the trunk
try this on the 3560:
conf t
vlan 100
exit
int gig0/1
Switchport trunk allowed vlan add 100
Also can you check the cores for vlan 100:
sh vlan brief
sh int trunk
res
Paul
Kind Regards
Paul
d.navetto
the vlan 100 don't work in my network... the DG refer to vlan 101
d.navetto
the picture above is a example only your explication it's no real the tag of vlan 100 don't work in my network
Hello David,
If i correctly understand, your issue was.
clients(vlan 360) on switch 3560 not able to access or ping default gateway which is on server firm switch and server on firm switch which is on same vlan.
We are use trunk link  between switches insted on access link to carry traffic from all vlans over single link with vlan tagging information so each receving switch must identify for which vlan a frame belongs to.Vlan tag information append by first switch the network and remove by last switch in the network where packet send over edge port .In your network you are trying to ping from vlan 360 to gateway which is on firm switch (6513).As frames leaves switch 3560 it append vlan tagg 360and as soon as frame receive on the core switch it  drops because vlan 360 is not defind on core switch.
Please configure following way.
The CAT6909-1
spanning-tree vlan 100,360,900 priority 8192
interface Vlan100
interface Vlan900
interface Vlan 360
standby 1 ip 172.21.36.1--------------------------------gateway for vlan 360
The CAT6913-1
remove all config from The CAT6913-1and configure switch port as access vlan 360 on which server is connected.
Do not forget to create all vlans on this firm switch also but do not configure int mode for them.
Ok It' s a possible solution but it isn't applicable because the server lan is native on this 6513. Otherwise i think it can't help propagating this vlan to the switch access.
From my troubleshooting information, I suppose that the problem is regarding the L3/L2 between the 6513s and the 6509s.
Hello david,
You say you can ping from the distribution and core, but not from this switch?
can you post the running config of that switch, also
sh standby brief
sh spanning-tree blocked ports
sh spanning-tree vlan 360
sh int trunk
sh vlan brief
res
Paul
Kind Regards
Paul
