Ping between 2 private network
Layer_Two
Hi Chaps,
I have a Cisco 1841 and i am trying to configure it to create a new network for my esxi lab environment.
my home network is 192.168.1.0/24
Lab network is 192.168.100.0/24
My problem is that from the ESXi host which has 192.168.100.111 I can ping successfully 192.168.1.1 but nothing else on that network.
Oddly I can also ping 8.8.8.8 from the 192.168.100.0 network
Here is my very basic config:
Router(config-if)#do sh run
Building configuration...
Current configuration : 943 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
archive
 log config
  hidekeys
interface FastEthernet0/0
 description home network
 ip address 192.168.1.10 255.255.255.0
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 description Esxi network
 ip address 192.168.100.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
no ip http server
no ip http secure-server
control-plane
line con 0
 password cisco
 logging synchronous
 login
line aux 0
line vty 0 4
 password cisco
 login
line vty 5 807
 password cisco
 login
scheduler allocate 20000 1000
end
From my Esxi:
~ # traceroute 192.168.1.1
traceroute to 192.168.1.1 (192.168.1.1), 30 hops max, 40 byte packets
 1  192.168.100.1 (192.168.100.1)  0.912 ms  0.794 ms  0.821 ms
 2  192.168.1.1 (192.168.1.1)  0.621 ms  0.489 ms  0.453 ms
~ # traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 40 byte packets
 1  192.168.100.1 (192.168.100.1)  0.901 ms  0.849 ms  0.858 ms
 2  192.168.1.1 (192.168.1.1)  0.957 ms  0.487 ms  0.536 ms
 3  10.55.212.42 (10.55.212.42)  3.015 ms  2.310 ms  2.151 ms
 4  10.55.213.41 (10.55.213.41)  1.825 ms  2.023 ms  2.423 ms
 5  google1.lonap.net (5.57.80.136)  7.868 ms  7.815 ms  7.865 ms
 6  216.239.47.223 (216.239.47.223)  9.523 ms  8.762 ms  9.034 ms
 7  72.14.236.25 (72.14.236.25)  12.725 ms  15.288 ms  10.868 ms
 8  google-public-dns-a.google.com (8.8.8.8)  8.577 ms  8.594 ms  10.104 ms
~ # traceroute 192.168.1.101
traceroute to 192.168.1.101 (192.168.1.101), 30 hops max, 40 byte packets
 1  192.168.100.1 (192.168.100.1)  0.916 ms  0.851 ms  0.833 ms
 2  * *
Pinging anything into the 192.168.1.0 except 192.168.1.1 just fails!
On my home router I created a static as per below:
static
Am I missing something with NAT here?
Layer_Two
Hmmm
Think the problem could be the 2 gateways on the 192.168.1.0 network - 192.168.1.1 for my home router and 192.168.1.10 as router interface fa0/0
Could you please change your f0/0 ip address to 192.168.1.1?
As you have configured that as default route but were is that pointed/configured?
Inayath
