Ping between switches
opnineopnine
Level 7
Level 7
I have 2 switches that they are connected directly. both have the same vlan 20 for access.  I created a new vlan 100 this is a mgmt vlan, on both devices and create a SVI. On the interface that connects this 2 devices I added the vlan 100. so I have vlan 20, 100 between them, but when I ping between this 2 devices I dont get any answer.
Thanks in advance.
Hello
Just to clarify -
Both switches example
int vlan 100
ip address 100.100.100.x 255.255.252
vlan 20,100
exit
Int x/x
description PC
siwtchport host
switchport access vlan 20
int xx
description TRUNK to swX
switchport trunk enc dot1q
switchport mode trunk
res
Paul
Kind Regards
Paul
5 Replies 5
Ben Walters
Level 9
Level 9
Thanks in advance.
You can check the following.
Both devices have vlan 100 created.
Both have an IP address assigned to their vlan 100 interface
Both devices are set for trunk ports on the interface that connects them and allow vlan 100
If all this is true you should be able to ping one switch from the other on vlan 100. If it is true and you are still unable to ping between them try specifying the source for the ping command.
ping <IP address> source vlan 100
Hello
I was not working , what I did was "switchport trunk encapsulation dot1q"
Thanks !!
Hello
Just to clarify -
int vlan 100
vlan 20,100
exit
Int x/x
description PC
siwtchport host
int xx
res
Paul
Kind Regards
Paul
To help us understand what is going on here please provide the output on both switches to these commands:
show ip interface brief
show interface trunk
Rick
Rick
Julio E. Moisa
Is the VLAN 100 created on both switches? also you can apply shutdown and no shutdown to the SVI 100, In some cases the new SVI are shutdown.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
