Ping fail between physical Router interface and subinterface
amit.koolmar
Community Member
I am trying to set up a small lab, where I have 2 PCs, 1 switch and 1 Router.
The 2 PCs are 192.168.10.1/24 (Vlan 10), D.G. 192.168.10.254/24 and, PC2: 192.168.20.1/24 (Vlan 20), D.G. 192.168.10.254/24.
Router has a subinterface fa0/0.20 for vlan 20, which PC2 is able to ping. However, ping from PC1 to it's D.G. 192.168.10.254 fails, which is an IP address on a physical interface fa0/0.
Trunking is enabled between between the switch and the router. Can somebody please advise what's wrong with the config?
Please see the the Router and Switch config below. Thank you.
Router config:
Router#sh run
Building configuration...
Current configuration : 666 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 192.168.10.254 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
 Switch config:
Switch#sh run
Current configuration : 1102 bytes
version 12.1
hostname Switch
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
switchport access vlan 20
interface FastEthernet0/3
switchport mode trunk
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch# sh vlan brief
VLAN Name Status Ports
1 default active Fa0/4, Fa0/5, Fa0/6, Fa0/7
Fa0/8, Fa0/9, Fa0/10, Fa0/11
Fa0/12, Fa0/13, Fa0/14, Fa0/15
Fa0/16, Fa0/17, Fa0/18, Fa0/19
Fa0/20, Fa0/21, Fa0/22, Fa0/23
Fa0/24
10 MGMT active Fa0/1
20 HR active Fa0/2
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
ahmedshoaib
Level 9
Level 9
Hi;
Please create sub-interface for vlan 10 also on router and remove the configuration on F0/0:
no ip address
interface FastEthernet0/0.10
encapsulation dot1Q 10
Thanks & Best regards;
Thank you sir!  But shouldn't the ping between physical interface and subinterface work as well?
Hi Amit,
From pc in vlan 10 can ping the 192.168.10.254 and PC in vlan 20 can ping 192.168.20.254?
In your scenario we can not assigned ip add on the physical interface. IP will be assigned on sub-interface f0/0.10 & f0/0.20
