Ping from vlan interfaces on 3750 switch
Daniel McLean
Hi all,
I'm having some trouble getting my head round the following but I think it's routing related?
I have a Cisco 3750 switch with the following configured:
interface Vlan1
ip address 192.168.0.223 255.255.254.0
no ip route-cache
interface Vlan6
ip address 10.74.6.1 255.255.255.0
no ip route-cache
interface Vlan8
ip address 10.74.8.1 255.255.255.0
no ip route-cache
interface Vlan10
ip address 10.74.10.1 255.255.254.0
no ip route-cache
interface Vlan14
ip address 10.74.14.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.254
The 3750 is connected to a firewall which handles the routing.  From the 3750 I can only ping remote networks from the vlan1 interface not from vlan6,8 or 10 i.e ping 10.34.37.101 (remote network) source 192.168.0.223 (vlan1) works but ping 10.34.37.101 source 10.74.10.1 (vlan10) does not?  I can ping 10.34.37.101 from computers on the various vlans but not from the 3750 it self.
I looked at setting a default gateway for the various vlan interfaces but couldn't find any information so I guess my logic for that is wrong?
Any suggestions?
Richard Burts
Daniel
We need some additional information before we would be able to give you good suggestions about this issue.
- You have configured multiple vlan interfaces on the 3750 which implies that  ip routing is enabled on the 3750. Can you verify whether ip routing is enabled on the 3750?
- would you post the output of show ip route from the 3750?
- would you post the output of show ip interface brief from the 3750?
Rick
Rick
Hi Richard,
ip routing is not enabled but I have been switching it on to try and get this working.  When it's not enabled I think the
ip default-gateway 192.168.0.254 comes into play and when it is enabled show ip route shows the following:
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C       10.74.6.0/24 is directly connected, Vlan6
C       10.74.8.0/24 is directly connected, Vlan8
C       10.74.10.0/23 is directly connected, Vlan10
C       10.74.14.0/24 is directly connected, Vlan14
C    192.168.0.0/23 is directly connected, Vlan1
Show ip int bri:
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  192.168.0.223   YES NVRAM  up                    up
Vlan6                  10.74.6.1       YES manual up                    up
Vlan8                  10.74.8.1       YES manual up                    up
Vlan10                 10.74.10.1      YES manual up                    up
Vlan14                 10.74.14.1      YES manual up                    up
FastEthernet0          unassigned      YES NVRAM  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  up                    up
GigabitEthernet1/0/2   unassigned      YES unset  up                    up
GigabitEthernet1/0/3   unassigned      YES unset  up                    up
GigabitEthernet1/0/4   unassigned      YES unset  up                    up
GigabitEthernet1/0/5   unassigned      YES unset  up                    up
GigabitEthernet1/0/6   unassigned      YES unset  up                    up
GigabitEthernet1/0/7   unassigned      YES unset  up                    up
GigabitEthernet1/0/8   unassigned      YES unset  up                    up
GigabitEthernet1/0/9   unassigned      YES unset  up                    up
GigabitEthernet1/0/10  unassigned      YES unset  up                    up
GigabitEthernet1/0/11  unassigned      YES unset  up                    up
GigabitEthernet1/0/12  unassigned      YES unset  up                    up
GigabitEthernet1/0/13  unassigned      YES unset  up                    up
GigabitEthernet1/0/14  unassigned      YES unset  up                    up
GigabitEthernet1/0/15  unassigned      YES unset  up                    up
GigabitEthernet1/0/16  unassigned      YES unset  up                    up
GigabitEthernet1/0/17  unassigned      YES unset  down                  down
GigabitEthernet1/0/18  unassigned      YES unset  down                  down
GigabitEthernet1/0/19  unassigned      YES unset  down                  down
GigabitEthernet1/0/20  unassigned      YES unset  down                  down
GigabitEthernet1/0/21  unassigned      YES unset  down                  down
GigabitEthernet1/0/22  unassigned      YES unset  down                  down
GigabitEthernet1/0/23  unassigned      YES unset  down                  down
GigabitEthernet1/0/24  unassigned      YES unset  down                  down
GigabitEthernet1/0/25  unassigned      YES unset  down                  down
GigabitEthernet1/0/26  unassigned      YES unset  down                  down
GigabitEthernet1/0/27  unassigned      YES unset  down                  down
GigabitEthernet1/0/28  unassigned      YES unset  down                  down
GigabitEthernet1/0/29  unassigned      YES unset  down                  down
GigabitEthernet1/0/30  unassigned      YES unset  down                  down
GigabitEthernet1/0/31  unassigned      YES unset  down                  down
GigabitEthernet1/0/32  unassigned      YES unset  down                  down
GigabitEthernet1/0/33  unassigned      YES unset  down                  down
GigabitEthernet1/0/34  unassigned      YES unset  down                  down
GigabitEthernet1/0/35  unassigned      YES unset  down                  down
GigabitEthernet1/0/36  unassigned      YES unset  down                  down
GigabitEthernet1/0/37  unassigned      YES unset  down                  down
GigabitEthernet1/0/38  unassigned      YES unset  down                  down
GigabitEthernet1/0/39  unassigned      YES unset  down                  down
GigabitEthernet1/0/40  unassigned      YES unset  down                  down
GigabitEthernet1/0/41  unassigned      YES unset  down                  down
GigabitEthernet1/0/42  unassigned      YES unset  down                  down
GigabitEthernet1/0/43  unassigned      YES unset  down                  down
GigabitEthernet1/0/44  unassigned      YES unset  down                  down
GigabitEthernet1/0/45  unassigned      YES unset  down                  down
GigabitEthernet1/0/46  unassigned      YES unset  down                  down
GigabitEthernet1/0/47  unassigned      YES unset  down                  down
GigabitEthernet1/0/48  unassigned      YES unset  up                    up
GigabitEthernet1/1/1   unassigned      YES unset  down                  down
GigabitEthernet1/1/2   unassigned      YES unset  down                  down
GigabitEthernet1/1/3   unassigned      YES unset  down                  down
GigabitEthernet1/1/4   unassigned      YES unset  down                  down
Te1/1/1                unassigned      YES unset  down                  down
Te1/1/2                unassigned      YES unset  down                  down
GigabitEthernet2/0/1   unassigned      YES unset  up                    up
GigabitEthernet2/0/2   unassigned      YES unset  up                    up
GigabitEthernet2/0/3   unassigned      YES unset  up                    up
GigabitEthernet2/0/4   unassigned      YES unset  up                    up
GigabitEthernet2/0/5   unassigned      YES unset  up                    up
GigabitEthernet2/0/6   unassigned      YES unset  up                    up
GigabitEthernet2/0/7   unassigned      YES unset  up                    up
GigabitEthernet2/0/8   unassigned      YES unset  up                    up
GigabitEthernet2/0/9   unassigned      YES unset  up                    up
GigabitEthernet2/0/10  unassigned      YES unset  up                    up
GigabitEthernet2/0/11  unassigned      YES unset  down                  down
GigabitEthernet2/0/12  unassigned      YES unset  down                  down
GigabitEthernet2/0/13  unassigned      YES unset  down                  down
GigabitEthernet2/0/14  unassigned      YES unset  down                  down
GigabitEthernet2/0/15  unassigned      YES unset  down                  down
GigabitEthernet2/0/16  unassigned      YES unset  down                  down
GigabitEthernet2/0/17  unassigned      YES unset  down                  down
GigabitEthernet2/0/18  unassigned      YES unset  down                  down
GigabitEthernet2/0/19  unassigned      YES unset  down                  down
GigabitEthernet2/0/20  unassigned      YES unset  down                  down
GigabitEthernet2/0/21  unassigned      YES unset  down                  down
GigabitEthernet2/0/22  unassigned      YES unset  down                  down
GigabitEthernet2/0/23  unassigned      YES unset  down                  down
GigabitEthernet2/0/24  unassigned      YES unset  down                  down
GigabitEthernet2/0/25  unassigned      YES unset  up                    up
GigabitEthernet2/0/26  unassigned      YES unset  up                    up
GigabitEthernet2/0/27  unassigned      YES unset  up                    up
GigabitEthernet2/0/28  unassigned      YES unset  down                  down
GigabitEthernet2/0/29  unassigned      YES unset  down                  down
GigabitEthernet2/0/30  unassigned      YES unset  down                  down
GigabitEthernet2/0/31  unassigned      YES unset  down                  down
GigabitEthernet2/0/32  unassigned      YES unset  down                  down
GigabitEthernet2/0/33  unassigned      YES unset  down                  down
GigabitEthernet2/0/34  unassigned      YES unset  down                  down
GigabitEthernet2/0/35  unassigned      YES unset  down                  down
GigabitEthernet2/0/36  unassigned      YES unset  down                  down
GigabitEthernet2/0/37  unassigned      YES unset  down                  down
GigabitEthernet2/0/38  unassigned      YES unset  down                  down
GigabitEthernet2/0/39  unassigned      YES unset  down                  down
GigabitEthernet2/0/40  unassigned      YES unset  down                  down
GigabitEthernet2/0/41  unassigned      YES unset  down                  down
GigabitEthernet2/0/42  unassigned      YES unset  down                  down
GigabitEthernet2/0/43  unassigned      YES unset  down                  down
GigabitEthernet2/0/44  unassigned      YES unset  down                  down
GigabitEthernet2/0/45  unassigned      YES unset  down                  down
GigabitEthernet2/0/46  unassigned      YES unset  down                  down
GigabitEthernet2/0/47  unassigned      YES unset  down                  down
GigabitEthernet2/0/48  unassigned      YES unset  down                  down
GigabitEthernet2/1/1   unassigned      YES unset  down                  down
GigabitEthernet2/1/2   unassigned      YES unset  down                  down
GigabitEthernet2/1/3   unassigned      YES unset  down                  down
GigabitEthernet2/1/4   unassigned      YES unset  down                  down
Te2/1/1                unassigned      YES unset  down                  down
Te2/1/2                unassigned      YES unset  down                  down
Port-channel1          unassigned      YES unset  up                    up
Once ip routing is enabled I can't ping anything other than connected networks until I set a default route, i.e ip route 0.0.0.0 0.0.0.0 10.74.11.254
but my main problem is from a remote network I can only ping the vlan interface that has the default gateway set, so for example ip route 0.0.0.0 0.0.0.0 192.168.0.254 allows me to ping vlan1 remotely if I change this default route to 10.74.8.254 (the gw for vlan8) then vlan8 interface is now the only vlan interface on the Cisco 3750 I can ping remotely?
Daniel
If the intent is that the 3750 should not have IP routing enabled then lets turn it off and then figure out what the underlying issue is and how to fix it.
If IP routing is not to be enabled then the 3750 should have only one layer 3 vlan interface configured (and that should be VLAN 1). Multiple vlan interfaces make sense when IP routing is enabled and it allows the 3750 to route between VLANs. But with IP routing not enabled I would suggest that you remove all but one of the interface vlan x.
Having a single interface vlan x will allow management access to the switch and will allow the switch supervisor to access other network resources. It will not have any impact on layer 2 forwarding or on layer 3 forwarding. And you are correct that in this case the ip default-gateway is configured and used to allow the switch to access IP addresses that are not in the same subnet as its management interface.
I suspect that when you have made the change so that the 3750 has only the VLAN 1 layer 3 interface that layer 2 and layer 3 forwarding will work and that the switch should be able to access the necessary network resources. If that is not the case then we need to check on a few other things. But it looks to me like the issues that you describe are the result of attempting multiple layer 3 interfaces on a switch that is operating at layer 2.
Rick
Rick
