Bookmark
Subscribe
943
Ping Sweeps to test for packet loss on both router and host ends.
bruce.porter
Does anyone know of a simple DOS batch mode or Linux script to ping a specified set of subnets with large numbers of pings? Purpose is to look for link problems not normally detected on the network-side equipment.
Something like this would work. This script will ping every address from .1 to .254 on each of the specified subnets. It will send one ping packet to each host:
## BEGIN script
proc pingSweep { } {
set subnet "10.0"
set octets [list 1 2 3 4 5 10 11 12 13 14 15 16 17 18 19 20]
for { set i 0 } { $i < [llength $octets] } { incr i } {
for { set j 1 } { $j < 255 } { incr j } {
set addr "${subnet}.[lindex $octets $i].${j}"
ping $addr repeat 1
pingSweep
## END script
Router#tclsh flash:pingSweep.tcl
This assumes you save this script into the router's flash as pingSweep.tcl. You could also type all of this in once you enter tclsh in IOS.
umedryk
Level 5
Level 5
The following example will ping the ip address and will send 10 packets. Like wise specify the ip addresses that needs to be pinged
Router1#tclsh
Router1(tcl)#foreach i {
10.10.10.6
} { ping $i repeat 10 }
Very interesting. I take it the clsh command puts you in the tool control language. I am not familiar with tcl. Can you elaborate on how you would select, say a range of ip subnets of 10.0.1.0, and 10.0.5.0? Also 10.0.10.0 through 10.0.20.0. thx
## BEGIN script
set subnet "10.0"
ping $addr repeat 1
pingSweep
## END script
Worked as advertised. thx
