Planning without IGP on Nexus
sampathkumar.s
hi team,
planning for without any IGP or SVIs on Nexus? Distribution or access will be configured with SVIs. is it a good option.
In my opinion it is not going to be a good design. Nexus is a full-featured switch and you would loose most of them planning a flat network running on Nexus. Bear in mind that an igp is providing control and functionalities.. At last, what you mean "without SVI" ? Do you want to set it up as a flat vlan 1 or what?
Hope this helps
Alessio
mhnedirli
What are you planning to do. If you want to use nexus as l2 device you could use another switch
Sent from Cisco Technical Support Android App
