Showing results forĀ
Search instead forĀ
Did you mean:Ā
%PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi0/20 can't be brought up because it failed POST in Inline Power test
getaway51
Level 2
Level 2
This error happened after I 'shut' and 'no shut' the ports. Seems  Interface range command failed for GigabitEthernet0/17.
I tried to 'no shut' the ports now, but it remains as administratively disabled or shutdown.
Hardware issue? Cisco 3650-48-PS
%PLATFORM_ENV-3-ILP_PORT_POST_ERR: Gi0/17 can't be brought up because it failed POST in Inline Power test
% Interface range command failed for GigabitEthernet0/17
2 Accepted Solutions
Reza Sharifi
This appears to be hardware issue. I would open a ticket with TAC and see if this is known bug. If they don't have a solution, you can just RMA it.
Leo Laohoo
The appliance is dead.
Contact Cisco TAC and organize for an RMA.
Reza Sharifi
marce1000
 - You may also verify if this problem remains in place if you use the latest software version.
 M.
Leo Laohoo
shservice
I solved this problem by upgrading IOS怂
