10-13-2014 04:15 PM - edited 03-07-2019 09:05 PM
Please help me configure my 2651xm router.
My DSL line has a modem of Zyxel P-2612 and I want to connect it to fa0/0 on 2651xm and fa0/1 to switch..
anyone help me configure this connection?
Thank you in advance..
10-13-2014 06:04 PM
Do you have any existing configuration? Your config should look something like this:
interface F8
ip nat inside
interface G0
ip nat outside
ip access-list standard NAT
permit 192.168.11.0 0.0.0.255
ip nat inside source list NAT interface G0 overload
10-14-2014 06:42 AM
If your modem has one ethernet or Fastethernet port, you can connect it directly on you f0/0 and connect you switch on f0/1 port,
secondly, give those IP addresse, and activate routage.
Exemple:
Router(config) int f0/0
Router(config-if)ip address 63.0.0.1 255.255.255.0
Router(config-if)no shut
Router(config)int f0/1
Router(config-if) ip address 10.0.0.1 255.0.0.0
Router(config) ip route 0.0.0.0 0.0.0.0 fa0/0
this simply configuration cant work fine il you have modem with port Ethernet or Fastethernet port
Good luck,
CEDRIC
