PoE is not working on SM-ES3G-24-P Module
Andrewkai
I am working for a voice project now. Unfortunately the PoE feature is not working in my switch Module.
When I connect to my cisco IP phone, it doesn't provide the power.
What will be the cause? Do I need to configure for PoE?
Appreciate your Help!
Sincerely,
Andrew
Andrew,
Call "sh inventory" or "sh diag" and check that module PoE status.
You should check power supply also where as PoE or AC.
HTH.
Cheer!
PK
lgijssel
Level 9
Level 9
From what I read in the configuration guide, power should be enabled by default.
http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#wp1920081
The command to configure is: power inline {auto [max max-wattage] | never | static [max max-wattage]}
You may try " sh power inline" to get an idea of what might be wrong.
Referring to the first link, the docs for configuring the module are those for the 2960:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swint.html#wp2047530
regards,
Leo
Andrew,
HTH.
Cheer!
PK
Oh I see. Mine is AC power supply.
NAME: "C2911 AC Power Supply", DESCR: "C2911 AC Power Supply"
That's why switch module is not providing inline power. No wonder
So, I have to change it to PoE power supply.
Thanks a lot.
Cheer!
Andrew
Hi Andrew,
How did you change the config to PoE mode from AC? Would you be ablle to share?
My router also shows:
but cant figure out how to change it to PoE.
