10-17-2007 07:18 PM - edited 03-05-2019 07:09 PM
Hello!
I have a 48 ports PoE that does not supply power to devices. I get this error:
ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Fa0/1
: Power given, but Power Controller does not report Power Good
Any tip? help?
10-17-2007 07:53 PM
Try updating the IOS image, if the problem persists, it may be a hardware problem. You need to open a TAC case for a RMA.
10-17-2007 08:53 PM
Hi Edison:
IOS was updated from 12.2(25)SEB4 to 12.2(25)SEE4, and problem persits.
Jacinto
10-17-2007 08:41 PM
Hi Jacin,
I will like to know the exact image or IOS release you are running on this box and what is connecte don this interface (fa0/1)? Is this the only interface giving you an error message or any other interface also reports same issue?
Ankur
10-17-2007 08:50 PM
Hi Ankur:
IOS version is 12.2(25)SEE4. I have connected Cisco IP Phone 79xx. All ports report the same problem.
Jacinto
10-17-2007 09:12 PM
Hi Jacinto,
Were these ports connected to some non POE device earlier and now you started plugging ip phones? Or it was always with poe devices?
Ankur
10-17-2007 09:24 PM
Some ports had non POE but most of them just IP Phones. This Fa0/1 always had an ip phone 7910G
Jacinto
10-17-2007 09:31 PM
Hi Jacinto,
Can you give a try with this command "power inline static" and then shut and no shut on this port and if this does not work then is it posible for you to upgrade to 12.2(40)SE release and if not I believe you have to go with the option mentioned by Edison contacting TAC.
Ankur
10-17-2007 10:41 PM
Hi Ankur:
I updated to 12.2(40)SE release and problem persits. Thank you very much for your help! I think I have to contact TAC as Edison mentioned.
If you found something else related to this please let me know.
Jacinto
10-17-2007 11:36 PM
