10-26-2018 05:27 AM - edited 03-08-2019 04:29 PM
We have a Cisco SG350-28P 28-Port Gigabit PoE Managed Switch on a Customer Site witch have to provide Power over Ethernet to the Desk Phones (Series 8800). The normal phones (8851) are working as expected. But the Phones with the digital Key Expansion Module attached don't get enough power for enabling the KEM. As Documents say normal PoE should be enough for powering one Module.
We have updated the Switch to the newest Software Version 2.4.0.94 but it doens't help.
The Switch Logs don't show any error for PoE. Only the Phones display on startup that they can't enable the KEM because of insufficent Power.
Have someone a solution for that problem?
10-26-2018 05:41 AM
try and use Power Mode --> Class Limit (page 167 of the attached manual).
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350xg/admin_guide/AG_Tesla_350_550.pdf
10-26-2018 05:44 AM
That is the active Setting under Port Management -> PoE -> Properties.
I have also tried Port Limit but no change. KEM not powering up
10-26-2018 05:47 AM
What if you increase the power allocation ?
Port Management > PoE > Settings --> Administrative Power Allocation (mW)
10-26-2018 05:55 AM
Under PoE -> Settings -> Port X i can't change Power Allocation. It's seems thats this is only informational.
10-26-2018 06:00 AM
I think you need to have 'Port Limit' configured in order to change that value...
10-26-2018 06:13 AM
i have now changed the Power Setting to Port Limit. Now i can change the Power Allocation - But this is set to the max of 30000 mW
10-26-2018 06:28 AM
according to Table 4 in the attached document, you need 802.3at PoE. Check if you can change that somewhere in the settings of the switch...
10-26-2018 06:35 AM - edited 10-26-2018 06:36 AM
The Switchport is running with following power setting:
When i plug the phone incl. the KEM in a switch port on the old phone system (UC540) the phone with the KEM boots up.
Normaly it should run aroung 9-12 watts with that module.
10-26-2018 07:02 AM
are you running firmware 10.2(2) or later on your phones ?
10-26-2018 07:09 AM
I'm running currently firmware sip88xx.12-1-1SR1-4
10-26-2018 07:27 AM
for some reason the KEM is not compatible. I cannot find any information on whether it should or should not be.
If possible, try and downgrade your firmware to a 2.3, 2.2., or 2.1 release, and check if that makes a difference. Not very good advice, I know, as it is pretty much trial and error...
11-05-2018 06:56 AM
i have tried to downgrade the software on that switch. With Version 2.2 the problem still exists. After the Downgrade to 2.1 the switch didn't boot up again. Now the System stuck in a boot loop. With the console i see following error:
%HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: HALP_config_poe_number_of_poe_devices is Zero: Failed on init.
***** FATAL ERROR *****
Reporting Task: HCPT.
Software Version: 2.1.0.63 (date Jan 17 2016 time 14:41:37)
ros(HOSTG_fatal_error+0x14) [0x233edc]
ros(OSSYSG_fatal_error+0x148) [0x74d430]
ros() [0x582800]
ros(HALP_config_poe_692xx_dev_op_set_periodic+0x580) [0xa11a38]
ros() [0xa058f4]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation+0x48) [0xa059d8]
ros(HALC_config_poe_dev_operation+0x44) [0xa15044]
ros() [0x9bc26c]
ros(HALC_config_device_dispatch+0x1a4) [0x9c114c]
ros() [0x9d8ae8]
ros() [0x9d8cf4]
ros() [0x9d8d4c]
/lib/libp2linux.so.1(+0x3aa4) [0xb6ed5aa4]
/lib/libpthread.so.0(+0x6e64) [0xb6eb0e64]
***** END OF FATAL ERROR *****
This error is linked to Cisco BUG ID CSCvk62334 and the workaround is a RMA. So we will do this and let you know if the problem wie the poe provisioning for the Cisco IP Phone 8851 + 1 KEM still exists.
For now thank you for your help
