POE+ switch and normal POE device.
muhsinamol
Dear Team.
I have POE+ switch  and a normal POE camera.
My question can  I connect  the normal POE camera to POE+  switch ? is it make any problem for the camera which have only normal POE capability ?
Muhsina
devils_advocate
Level 7
Level 7
Yep it will be fine.
PoE+ just means the switch supports more power than the standard PoE, it doesn't mean you can only use devices which require PoE+ power.
