poe
leomni
Community Member
am i wrong or should a cat 3560 switch automaticlly do poe... if not what is the command to get that int up and running
4 Accepted Solutions
amit-singh
Level 11
Level 11
Which model is this. The switch should be POE enable.Paste the " show version" from the switch and let us check the model number of the switch.
It should give POE bydefault, if its POE enabled. Other wise you can go to interface config and set it up using " power inline auto" command under the interface. It should work for you.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/cr/cli1.htm#wp6776081
HTH, Please rate if it doe.
-amit singh
ankbhasi
Hi Friend,
If your 3560 is POE capable you need not do any special configuration and it will by default provide power to the device.
Cisco Catalyst 3560-24PS
24 Ethernet 10/100 ports with Power over Ethernet (PoE) and 2 SFP ports
Cisco Catalyst 3560-48PS
48 Ethernet 10/100 ports with PoE and 4 SFP ports
Cisco Catalyst 3560G-24PS
24 Ethernet 10/100/1000 ports with PoE and 4 SFP ports
Cisco Catalyst 3560G-48PS
48 Ethernet 10/100/1000 ports with PoE and 4 SFP ports
These 4 switches which has "PS" at the end of model name provides inline power.
To check some POE related configuration on switchports have a look at this link
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12235se/scg1/swint.htm#wp1811783
Ankur
*Pls rate helpfull post
Hi Friend,
I am afraid your switch is not POE capable.
Ankur
Hi Friend,
Check the model number in the "sh version" output you pasted and it says "WS-C3560-24TS" which is not a POE switch.
The POE switch model is like "WS-C3560-24PS-S" and the POE switch model ends with "PS"
You can check the different 3560 models in this link
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
Ankur
*Pls rate the post
9 Replies 9
amit-singh
Level 11
Level 11
-amit singh
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWAR
E (fc4)
Switch uptime is 42 minutes
System image file is "flash:/c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.
SEE2.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K byt
es of memory.
Processor board ID CAT1009Z4S2
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
yea it thought it should be by default and i tried the power inline auto command but it doesnt exist... do i need to up the ios ?
Hi Friend,
Ankur
leomni
Community Member
how do you know?.... mostly out of curiosity because i recived it under the impression that it is
Hi Friend,
Ankur
*Pls rate the post
leomni
Community Member
hmm but why whould it say poe on the switch, and have the button on the side that scrolls through and lights up the poe option?
Hi Friend,
Nor sure but may be the chassis which is made is quite similar for all the models and based on the integrated hardware it provides the POE.
Check this link and the model which you have does not mentions about POE.
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7f.html
The model which supports POE is been mentioned in the chart.
Ankur
ankbhasi
Hi Friend,
Ankur
