point to point (p2p) switching
Amirmahdi.M
Hi Everyone
My question might seem dumb but is there a way for a cisco 4500x to switch traffic between 2 interfaces (trunk or access) without MAC learning?
I mean like ASR routers that have VPWS(xconnect) running and only know left and right without any MAC learning.
Amir
2 Accepted Solutions
It by defualt bridge two interface'
But different when SW learn MAC and SW dont learn MAC is the
Unknown unicast flood
When SW learn mac it forward to specific port depend one mac table
When SW NOT learn mac it flood to all port in that vlan' this called unknown unicast.
MHM
Put both port in one vlan and SW will flood traffic between two ports.
The different between flood and forward' forward use tcan and flood use some addiotonal SW resource.
Note:- by defualt sw read l2 header and learn mac for any ingress traffic
MHM
9 Replies 9
MHM
Hi @MHM Cisco World
I dont want the traffic to flood on all ports.
This is what i had in mind:
If the traffic comes from Te1/1(Left) then forward it to Te1/2(right)
If the traffic comes from Te1/2(right) then forward it to Te1/1(Left)
p2p forwarding
without any mac learning.
thanks
Amir
MHM
Hello again @MHM Cisco World
Lets assume i have a 4500x32 and 2 Te Ports in one vlan.
Can we estimate how much additional resource (compared to normal) will it use to switch 8Gbps of traffic from one interface to another?
Amir
Amirmahdi.M
I wanted to disable mac learning to save resource   (AFAIK the switch can learn upto 55k MACs but each of our users have about 5-10k MAC addresses)
I needed something like a Router's L2vpn but on a switch. I dont think its possible.
Thanks for your help
Amir
55K MAC' are sure this max MAC can this SW save?
User have many MAC is it VM user ?
MHM
55k is the maximum number of MAC addresses 4500x can handle.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/data_sheet_c78-696791.html
The user is a local ISP and it's users's PPPoE traffic is going to pass through the switch.
I dont know the number of users but if we give this kind of service to a few more ISPs, we will surely face a problem with the switch.
I really wanted to replace the switch with an asr903 but its not possible at the moment.
Can we estimate how much additional resource the Unkown Unicast Flood will use for about 8 Gbps? (Vlan only having 2 Ports)
Amir
MHM
You want to replace asr900 BNG with c4500.
Hmm' that tricky Q' I will check.
For Mac the ASR see few mac address and PPPoE use session ID instead of Mac to forward traffic.
