VRFs
Johnson_Mo
I have a cat 9300 and need to configure it for 5 different VRFs which simulates different  L3 switches.
on R1, I have  two GRE tunnels to ESW1. my question is: can I configure VRFs on ESW1 instead of using R2,ESW2 (has few vlans),ESW3 (has few vlans) as physical devices? topology is shown in the attached picture:
I think you talking about below point
  • The VRF associated with the tunnel vrf command is the same as the VRF associated with the physical interface over which the tunnel sends packets (outer IP packet routing).
Router-c9300
Interface between Router and C9300 config with vrf RED
The C9300 have two tunnel each within one VRF and both use interface to Router as tunnel source
So
Interface tunnel 1
Tunnel vrf RED
Tunnel source interface (toward R)
Ip vrf forwarding BLUE
Interface tunnel 2
Tunnel vrf RED
Ip vrf forwarding Green
That meaning of this point' the tunnel source interface must config same as tunnel vrf.
6 Replies 6
if the SW support
vrf tunnel command
then you can use SW to config GRE tunnel.
MHM
thanks for replying boss!
my main goal is to get rid of the SW2,SW3 and R2 and configure VRFS on the CAT 9300 switch. is this possible?
these restriction for config GRE tunnel VRF aware in 9300 IOS XE
  • Both ends of the tunnel must reside within the same VRF. <<- only make sure both end use same VRF
  • The VRF associated with the tunnel by using the ip vrf forwarding command is the VRF that the packets are to be forwarded in as the packets exit the tunnel (inner IP packet routing).
  • The feature does not support the fragmentation of multicast packets passing through a multicast tunnel.
  • The feature does not support the ISIS (Intermediate System to intermediate system) protocol.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-6/configuration_guide/b_166_rtng_9300_cg/b_166_rtng_9300_cg_chapter_011.html
MHM
so, based one the doc, we can not associate multiple vrfs to one tunnel?
Router-c9300
So
Interface tunnel 1
Tunnel vrf RED
Interface tunnel 2
Tunnel vrf RED
First point I make it in blue color'
The tunnel source as we see above can config with vrf under physical interface' tunnel destination as restrictions mention must be reachable via same VRF as tunnel source.
MHM
