Policer vs Bandwitch vs Shaper
danimelocoton
Hi all,
I was deeping in forum about this concepts and how they work and in which terms we can use them. But I'm very confused about how will they work.  I'm preparing a QoS config for ASR1006 in one TenGiga subinterface. The subinterface connect to a 1,3Gbps circuit of our transport Provider. We have two clients in that circuit. We should assure 300Mbps for one client with a /22 network and no more than 300Mbps. The other client can use the rest of the available bandwitdh but if there is no enough demand of traffic for the other client, can use the other client bandwitdh. Probably the circuit will no be congested in a long time, but traffic will increase for the both clients. So my questions are:
1. Which is the best config combining shaper, bandwitdh, policer and priority?.
 I use this schema_only with shapers....should it works?
policy-map PARENT
CLASS class-default
shaper 1300000000
service-policy CHILD
policy-map CHILD
CLASS classclient1
shaper 300000000
Class class-default
shaper 1300000000
IP ACCESS-LIST CLIENT1
permit ip any x.x.x.x 0.0.3.255
Class-map classlcient1
match-all name client1
interface Tengig0/1/0.300
service-policy output PARENT
Which is the best config? Should I have to apply shaper at the PARENT POLICY-map and combine bandwitdh and policy in the child policy-map to do the job?.
Thank you very much. Any help will be appreciated.
Joseph W. Doherty
policy-map PARENT
 CLASS class-default
  shaper 1300000000
policy-map CHILD
 CLASS classclient1
  shaper 300000000
  bandwidth 300000000
 Class class-default
  bandwidth1000000000
Joseph W. Doherty
policy-map PARENT
 CLASS class-default
  shaper 1300000000
policy-map CHILD
 CLASS classclient1
  shaper 300000000
  bandwidth 300000000
 Class class-default
  bandwidth1000000000
