Policing vlan interface on 6500
mats.brynolf
I was wondering how policing works on a 6500 with PFC3/Sup720. I would like to setup policing to 5Mbit in one direction and 10Mbit in the other direction. Can I setup different policing on input and output vlan interface? What’s input and output on a SVI interface?
If I change the policing to just [service-policy input 5mbps] would that be enough to limit the traffic in both directions to 5Mbit?
class-map match-all catch_all
  match access-group 111
policy-map 5mbps
  class catch_all
   police cir 5000000 bc 26000 be 26000 conform-action transmit exceed-action drop violate-action drop
policy-map 10mbps
  class catch_all
   police cir 10000000 bc 26000 be 26000 conform-action transmit exceed-action drop violate-action drop
interface GigabitEthernet 1/1
switchport mode access
switchport access vlan 100
mls qos vlan-based
interface vlan 100
no ip address
service-policy output 10mbps
mls qos
Laurent Aubert
If you apply the policing on the VLAN interface, it's an aggregate policer which apply to any interface belonging to the VLAN. The sum of all the traffic received/send from/to any interface belonging to this VLAN will be policed.
It will also police routed traffic from this VLAN to another one.
Laurent.
Thanks for clarifying that Laurent.
But what if I want to setup different policing speeds on input and output vlan interface? Is that possible since there are no input/output directions like a physical interface?
