Policy Base Routing Switch C4510
r-barbosa
Hi all,
I have a switch c4510R and would like to use PBR(policy-base-routing), was searching on the cisco software advisor and did not find this functionality. So i can not use the PBR into c4510R?
Regards.
14 Replies 14
cowetacoit
it depends on the supervisor card. Post a show version.
Giuseppe Larosa
Hello Ricardo,
the answer is that this depends on the specific type of supervisor you have installed on it.
the newer SUPs 6E and probably 6 L E don't support it.
There have been other threads of collegues that have discovered this.
Other supervisor models support PBR.
see
http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html
for example sup V 10Ge supports PBR
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps6033/product_data_sheet0900aecd801c5c66_ps4324_Products_Data_Sheet.html
Hope to help
Giuseppe
actually PBR is supported on the Sup6 with the newest release 12.2-52.SG. It just came out May 20th. i was waiting for it to be released.
hi,
is release 12.2-52.SG for SUP6E is support for PBR?
ravi
Hi cowetacoit, have you got the PBR succesfully running with the IOS 12.2-52.SG ?
Thanks for your replay.
All the best.
above information is very helpfull,
But is there any workaround or alternate to use PBR on SUPs 6E.
Ravi
noc@patni.com
sorry, but I was busy in recent days below the show version
cisco WS-C4510R (MPC8540) processor (revision 13) with 524288K bytes of memory.
Processor board ID FOX093200W3
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Hi Giuslar,
My supervisor is V-10GE, but not supported PBR, at least when I enter the following commands he shows me the option "ip policy"
C4510(config)# interface TenGigabitEthernet 1/1
C4510(config-if)# ip p?
% Unrecognized command
C4510(config-if)#
My IOS is 12.2(52)SG
Regards.
Hello Ricardo,
is the interface configured for L3 or a switchport?
I think you need a valid L3 interface to be able to apply PBR (inbound)
Hope to help
Giuseppe
Hi Giuseppe,
sorry, but i configured in the interface vlan, the following.
c4510(config)# interface vlan 2
c4510(config-if)# ip address 172.20.0.1 255.255.0.0
c4510(config-if)# ip p?
c4510(config-if)#
Is this above interface a layer 3 interface?
regards
Hello Ricardo,
an SVI interface like vlan2 is a L3 interface indeed.
I wonder if it can be a question of feature set.
May you post
sh ver |inc image
to see the exact image name
Hope to help
Giuseppe
the file IOS image is cat4500-ipbasek9-mz.122-52.SG.bin, but i search on the cisco advisor and not found any IOS with support PBR.
Regards.
That is strange. That release on a Sup V 10G should support PBR.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/product_bulletin_c25-531034_ps6021_Products_Bulletin.html
I was waiting for about 4 months on the new 12.2-52 release because when i bought a sup 6 i assumed it included PBR (and Netflow) but it didn't.
Then i go the software advisor and field Engine CPU not available "Supervisor V-10GE". Then i choose CAT4500-SUP5-10GE and click "Next", when typing PBR its not found. have any suggestions or run the download of another IOS?
