05-08-2013 03:16 AM - edited 03-07-2019 01:14 PM
What are the requirement on 3750 to carry out policy based routing .
one is ios with ipservices.
Is there any other requiremt?
05-08-2013 04:02 AM
Hi Prashant,
2 things to check
1- To enable PBR, the switch or stack master must be running the IP services feature set.
2- The SDM template should be set to routing mode. { If it is other than routing then configure the command to change the same: sdm prefer routing and reload the switch for this change to take effect before configuring PBR.}
Ref:
REgards
Inayath
*Plz rate all usefull posts.
05-08-2013 05:56 AM
Thanks ,I think template is in routing mode.
show sdm prefer routing
"desktop routing" template:
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 0.5K
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
#show sdm prefer dual-ipv4-and-ipv6 routing
"desktop IPv4 and IPv6 routing" template:
number of unicast mac addresses: 1.5K
number of IPv4 unicast routes: 2.75K
number of directly-connected IPv4 hosts: 1.5K
number of indirect IPv4 routes: 1.25K
number of IPv6 multicast groups: 1K
number of directly-connected IPv6 addresses: 1.5K
number of indirect IPv6 unicast routes: 1.25K
number of IPv4 policy based routing aces: 0.25K
number of IPv4/MAC security aces: 0.5K
number of IPv6 policy based routing aces: 0.25K
number of IPv6 qos aces: 0.5K
number of IPv6 security aces: 0.5K
05-08-2013 10:12 AM
Hi Prashant,
Then you are good to go.
Inayath
