policy-map configuration problem in Catalyst 9200 IOS XE 17.09.04a
bensonlei
Hi, guys,
"Total output drops" are found in some switchports of my Cat9200L stack ( two switches stack ), that uses IOS XE Version 17.09.04a; and the "qos queue-softmax-multiplier 1200" can not solved the problem of all switchports, so I tried to configure policy-map for some switchports, however, the policy-map configuration can not be completed as the bottom;
My problem is the following problem ( class map class1 not configured):
Cat9200L#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Cat9200L(config)#policy-map test2
Cat9200L(config-pmap)#class class1
The policy-map example ( from cisco document
9500H(config)#policy-map test2
9500H(config-pmap)# class class1
9500H(config-pmap-c)# priority level 1
9500H(config-pmap-c)# queue-buffers ratio 50
9500H(config-pmap-c)# class class-default
9500H(config-pmap-c)# bandwidth remaining percent 100
