Policy-map counters not increasing for QOS
rick505d3
I am doing a lab test to verify QOS on a Cisco 2960s 49P switch. The service policy applied to the interface Gi1/0/1 seems to be working as Wireshark capture (on the uplink trunk ports) indicate all traffic is correctly marked ("ef" for testint purposes). However, none of the counters in "show policy-map int gi1/0/1" seems to be increasing.
Standard IP access list acl-01
    10 permit any
Class Map match-all cm-01 (id 4)
   Match access-group name acl-01
  Policy Map pm-01
    Class cm-01
      set dscp ef
interface GigabitEthernet1/0/1
switchport access vlan 240
switchport mode access
switchport voice vlan 234
spanning-tree portfast
service-policy input pm-01
#show policy-map  interface gi1/0/1
  Service-policy input: pm-01
    Class-map: cm-01 (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group name acl-01
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      Match: any
        0 packets, 0 bytes
        5 minute rate 0 bps
#show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
#show mls qos  interface gi1/0/1
Attached policy-map for Ingress: pm-01
trust state: not trusted
trust mode: not trusted
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
#show ver
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48LPS-L  15.0(2)SE2            C2960S-UNIVERSALK9-M
Has anyone else observed this ? A bug ?
Rick.
Peter Paluch
Hi Rick,
I believe this is normal behavior. On switches, many operations including QoS marking manipulation is performed in hardware while the show policy-map command shows you the software counters associated with the policy-map. As the hardware does not report back the number of packets handled by the policy-map (which could be quite intensive as these operations are performed at wire rate), the counters in the policy-map are not incremented. The same goes, for example, for ACLs - the counters displayed by individual ACL entries do not increase, either.
If you check out the command reference for this command at:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/15.0_2_se/command/reference/cli2.html#wp1948343
the documentation says: Though visible in the command-line help string, the control-plane and interface keywords are not supported, and the statistics shown in the display should be ignored.
Best regards,
Peter
Peter Paluch
Hi Rick,
Best regards,
Peter
Thanks Peter. That explains the behaviour.
Rick.
