Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to exit the 2511 session/Como salir de sesion de 2511
Hi All,
need help  I am able to get in to r1 device, but when I tried
the exit "CTRL+SHIFT+6" plus "x"doesn't work - I am using Windows 7/64 and PuTTY
Any Suggestions? / Thank you
Here is what I got
Current configuration:
version 11.1
service udp-small-servers
service tcp-small-servers
hostname IMAACCESSSERVER
interface Loopback0
ip address 10.10.10.10 255.255.255.255
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip host r1 2001 10.10.10.10
ip host r2 2002 10.10.10.10
ip host r3 2003 10.10.10.10
no ip classless
logging buffered
line con 0
line 1 16
no exec
exec-timeout 0 0
transport input telnet
line aux 0
line vty 0 4
login
end
2 Accepted Solutions
markeelen
Hi Antonio,
I'm running windows 7/64 and putty, with no problem, just a thought, the key sequence is CTRL+Shift+6, release these three then press x. Other than that, I can't see any reason why it's not working.
Cheers
Mark
Ok, you can put command  "transport input telnet" back to your line.
Are you doing CTRL+SHIFT+6 than release then x and NOT CTRL+SHIFT+6 x at the same time.
You have to release the keys after you do CTRL+SHIFT+6 and than press x.
7 Replies 7
Reza Sharifi
Have a look at this link for config example:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
Under line 1 16
Try removing this command and test again.
change with Secure CRT
and i totally agree with reze
rete it use full post
Thank you for your input on this issue
I tried the following
When I removed the
I got the following when I tried to connect to unit R1
IMAACCESSSERVER#r1
Trying r1 (10.10.10.10, 2001)...
% Connection refused by remote host
Also I change from PuTTY to Secure CRT
but still have the same issue
my next try is to get a diferent laptop with XPPSP3.. and let see what happens!
markeelen
Hi Antonio,
Cheers
Mark
GREAT.........
Reza Sharifi
and
markeelen
Working............Thank you for the Input... RELEASE the MAGIC word... Have a good day!!!
Glad to help Antonio.
Thanks for the rating!
Reza
