Policy Map Matching Packets Not Prioritizing
tom.gabriel
My policy map is looking for the dsc 5 for my Toshiba phone system to prioritize our inter VoIP. Packets are being matched, but not prioritized. I have allotted 384K for voice. The smallest pipe it travels through is 3 Megabit. I can't tell if the voice is needing prioritized, but the phone conversations break up and drop packets. Any ideas of where to look?
5 Replies 5
Edison Ortiz
Please post the relevant portion of the config along with the show policy-map interface output.
__
Edison.
Carbondale_Tower_CSI#sho policy-map interface vlan 107
Vlan107
Service-policy output: voice
Class-map: voice (match-any)
946947 packets, 202646658 bytes
5 minute offered rate 18000 bps, drop rate 0 bps
Match: ip dscp cs5
5 minute rate 18000 bps
Queueing
Output Queue: Conversation 265
Bandwidth 384 (kbps) Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
5754431 packets, 1679667342 bytes
5 minute offered rate 47000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
--More-- (total queued/total drops/no-buffer drops) 0/0/0
Carbondale_Tower_CSI#sho policy-map voice
Policy Map voice
Class voice
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps) Max Threshold 64 (packets)
Here is my policy-map output and my policy map. My toshiba phone system using dscp of cs5.
You aren't using priority (LLQ), you are using bandwidth which is quite different.
Bandwidth only kicks in during congestion and from the policy-map output, you haven't hit congestion. However, you don't want to place voice packets on regular queues as they tend to be dropped on any bursty situation. There is a reserved queue for things like that, it's called the priority queue.
Your policy map should look like this:
policy-map voice
class voice
priority 384
class class-default
HTH,
__
Edison.
hi edison,
how you confirmed from the output
there is no congestion
Bandwidth only kicks in during congestion.
You presented this output where the ACL is being matched (Note the maximum offered is 18kbps).
Match: ip dscp cs5
Now this is the portion where the Queueing kicsk in:
Queueing
As you see, no packets are being allocated here since there isn't any congestion.
__
Edison.
