Policy routing or offset list?
jkeeffe
Level 2
Level 2
I want to send a particular data stream (source-A  destination-B) through only one of two WAN routers to a remote site. The remote site also has two WAN routers. Traffic from source-A will travel through a core and distribution layer of 6500 L3 switches, running 12.2(33)SXH8, to the WAN routers which are two ASR1006s.  The remote end is the same - two ASR1006 WAN routers to 6500 distribution and Core L3 switches.  All 6500s are L3 uplinked to each other and to the WAN routers.  All traffic from the local site to the remote site routes throuh only one of the two WAN routers.  I want to move only traffic from source-A to source-B to the second WAN router to the remote site.
Would it be best to use policy-based routing or an offset list of some sort to accomplish this?  I've done PBR before where you just hand off traffic described in an ACL to a particular outbound port and basically hand carry the traffic to a point in the network where EIGRP prefers the route you want.
3 Accepted Solutions
Giuseppe Larosa
Hello Jkeeffe,
what is the root cause for :
Are you using HSRP on client vlans with  HSRP active for all clients on catalyst A?
Or actually the primary WAN routers provide better routes ( with a lower metric) and are used regardless of who is the default gateway (between the two C6500) on client vlans?
To be noted if the use of primary routers is driven only by HSRP or VRRP on client Vlans all you need to do is to have Catalyst B HSRP active for that specific subnet on site A and the same on site B.
(if EIGRP costs are equal between RA1-RB1 and RA2-RB2 WAN routers)
In any case, the use of offset list is possible if you mean from a whole subnet in site A to a whole subnet in site B and viceversa.
If so all you need to do is to make the two subnets with a better metric on WAN RA2 to WAN RB2 by applying offset lists on the primary WAN routers to have delay  metric component increased only for those two IP subnets.
If you mean at host level or more specific then subnet mask PBR is the only way to go.
Hope to help
Giuseppe
As I read the original post he wants to specify Source and Destination of the traffic. If it was sufficient to manage by destination then I agree that manipulating routing metrics would be sufficient. But if the criteria include both Source and Destination then I do not know anything that can do it other than PBR.
Rick
Rick
smehrnia
Level 7
Level 7
despite you have full L3 connectivity between your 6500 and WAN routers, PBR is probabely the best and most flexible way and if you've dont it before, then there should be no problem for you. you have to apply the route-map to your incomming (Source) interface(s).
Although if you want to control traffic path selection for both of your sites (A-to-B & B-to-A) then you have to do it on your both Sites. (Site A and Site B).
just for the record and public education purposes I lay down a example here :
access-list 25 permit ip 1.1.1.1
route-map EXAMPLE permit 10
   match ip address 25
   set ip next-hop 3.3.3.3
interface fa 0/1
   ip policy route-map EXAMPLE
plz Rate if it helped.
Soroush.
Hope it Helps!
Soroush.
Giuseppe Larosa
Hello Jkeeffe,
Hope to help
Giuseppe
Rick
Rick
Hello Richard,
I agree you are right on this
playing with offset lists would not provide this level of control just  a different path for selected destinations regardless of the source.
Thanks for your correction
Best Regards
Giuseppe
smehrnia
Level 7
Level 7
   match ip address 25
interface fa 0/1
Soroush.
Hope it Helps!
Soroush.
