port authentication methods
tedauction
Level 5
Level 5
Hello, regarding switchport port-security, the normal method is to allow based on MAC address.
I understand you can also use RADIUS 802.1x for this purpose.
My question is, is there any other form of port access authentication that can be used apart from these two ?
Thank you.
Francesco Molino
Those are the 2 possibilities to secure ports.
However, port security isn't a reliable method.
Within dot1x, you have several methods:
- MAC
- user/password
- certificate
- and web authentication even if it isn't used a lot for wired.
PS: Please don't forget to rate and mark add correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
- MAC
- user/password
- certificate
Francesco
Hello Francesco, thank you.
Why do you say 'port security isn't a reliable method' ?
Thank you.
Because it's based on Mac address and this is something that you can spoof very easily.
Francesco
