Port Authentication via Dot1x on 3560's via ACS 3.0
david.santel
I can't get port authentication to work.
ACS 3.0 using Radius
Cat 3560's
Windows EAP Type = MD5 Challenge
I get prompted to enter my password and it fails authentication. I am thinking something is mis-configured on the ACS 3.0. I am only trying it to get it to work on 1 port with one user at this point. Any ideas?
Cisco Config:
aaa authentication dot1x default group radius
radius-server host 10.20.1.25 auth-port 1645 acct-port 1646
radius-server key xxx
dot1x system-auth-control
interface GigabitEthernet0/3
switchport access vlan 10
switchport mode access
mls qos trust dscp
dot1x system-auth-control auto
spanning-tree portfast
ACS LOG:
05/05/2008 16:57:50 Bad request from NAS .. .. .. (Unknown) Invalid message authenticator in EAP request .. .. .. 10.20.1.18 .. .. .. .. .. MDF-SW-04 Radius
I get the above error when the switch is trying to authenticate me. Then windows errors out and says Authentication Failed.
Any ideas where I need to start troubleshooting this?
Thanks for the help!
Jagdeep Gambhir
Level 10
Level 10
David,
Sometimes the "Invalid message authenticator in EAP request" error message can occur due to mis-matched shared secret keys.
Please try resetting the shared password on the switch and the ACS to something simple like cisco123.
~JG
Do rate helpful posts
Below is the info from debug aaa authentication. Any ideas?
bend_idle_request_action called
110512: .May 6 09:08:42.196 UTC: dot1x-ev:dot1x_mgr_pre_process_eapol_pak: Role
determination not required on GigabitEthernet0/3.
110513: .May 6 09:08:42.196 UTC: dot1x-packet:dot1x_mgr_process_eapol_pak: queu
ing an EAPOL pkt on Authenticator Q
110514: .May 6 09:08:42.196 UTC: dot1x-ev:Enqueued the eapol packet to the glob
al authenticator queue
110515: .May 6 09:08:42.196 UTC: dot1x-packet:Received an EAPOL frame on interf
110516: .May 6 09:08:42.196 UTC: dot1x-ev:Received pkt saddr =00e0.b8a9.2085 ,
daddr = 0180.c200.0003,
pae-ether-type = 888e.0100.000f
110517: .May 6 09:08:42.196 UTC: dot1x-packet:Received an EAP packet on interfa
110518: .May 6 09:08:42.196 UTC: EAPOL pak dump rx
110519: .May 6 09:08:42.196 UTC: EAPOL Version: 0x1 type: 0x0 length: 0x000F
110520: .May 6 09:08:42.196 UTC: dot1x-packet:Received an EAP packet on the Gig
abitEthernet0/3 from mac 00e0.b8a9.2085
110521: .May 6 09:08:42.196 UTC: dot1x-sm:Posting EAPOL_EAP on Client=37E05D8
110522: .May 6 09:08:42.196 UTC: dot1x_auth_bend Gi0: during state auth_ben
d_request, got event 6(eapolEap)
110523: .May 6 09:08:42.196 UTC: @@@ dot1x_auth_bend Gi0: auth_bend_request ->
auth_bend_response
b8a9.2085:auth_aborting_enter called
110855: .May 6 09:10:47.381 UTC: dot1x-sm:Posting AUTH_ABORT on Client=37E05D8
110856: .May 6 09:10:47.381 UTC: dot1x_auth_bend Gi0: during state auth_ben
d_response, got event 1(authAbort)
110857: .May 6 09:10:47.381 UTC: @@@ dot1x_auth_bend Gi0: auth_bend_response ->
auth_bend_initialize
110858: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_bend_respon
se_exit called
110859: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_bend_initia
lize_enter called
110860: .May 6 09:10:47.381 UTC: dot1x_auth_bend Gi0: idle during state aut
h_bend_initialize
110861: .May 6 09:10:47.381 UTC: @@@ dot1x_auth_bend Gi0: auth_bend_initialize
-> auth_bend_idle
110862: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_bend_idle_e
nter called
110863: .May 6 09:10:47.381 UTC: dot1x-sm:Posting !AUTH_ABORT on Client=37E05D8
110864: .May 6 09:10:47.381 UTC: dot1x_auth Gi0: during state auth_aborting
, got event 20(no_eapolLogoff_no_authAbort)
110865: .May 6 09:10:47.381 UTC: @@@ dot1x_auth Gi0: auth_aborting -> auth_rest
art
110866: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_aborting_ex
it called
110867: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_restart_ent
er called
110868: .May 6 09:10:47.381 UTC: dot1x-ev:Resetting the client 00e0.b8a9.2085
110869: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_aborting_re
start_action called
110870: .May 6 09:10:47.381 UTC: dot1x-sm:Posting !EAP_RESTART on Client=37E05D
8
110871: .May 6 09:10:47.381 UTC: dot1x_auth Gi0: during state auth_restart,
got event 6(no_eapRestart)
110872: .May 6 09:10:47.381 UTC: @@@ dot1x_auth Gi0: auth_restart -> auth_conne
cting
110873: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_connecting_
enter called
110874: .May 6 09:10:47.381 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_restart_con
necting_action called
110875: .May 6 09:10:48.413 UTC: dot1x-packet:Received an EAP request packet fr
om EAP for mac 00e0.b8a9.2085
110876: .May 6 09:10:48.413 UTC: dot1x-sm:Posting RX_REQ on Client=37E05D8
110877: .May 6 09:10:48.413 UTC: dot1x_auth Gi0: during state auth_connecti
ng, got event 10(eapReq_no_reAuthMax)
110878: .May 6 09:10:48.413 UTC: @@@ dot1x_auth Gi0: auth_connecting -> auth_au
thenticating
110879: .May 6 09:10:48.413 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_authenticat
ing_enter called
110880: .May 6 09:10:48.413 UTC: dot1x-sm:Gi0/3:00e0.b8a9.2085:auth_connecting_
authenticating_action called
Anybody have any ideas what the log below is telling me?
Log Buffer (32768 bytes):
112712: .May 6 10:51:16.668 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3,
changed state to down
112713: .May 6 10:51:19.235 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3,
changed state to up
112714: .May 6 10:51:28.589 UTC: AAA/BIND(00000047): Bind i/f
112715: .May 6 10:51:28.589 UTC: AAA/AUTHEN/19 (00000047): Pick method list 'de
fault'
112716: .May 6 10:51:59.610 UTC: AAA/BIND(00000047): Bind i/f
112717: .May 6 10:51:59.610 UTC: AAA/AUTHEN/19 (00000047): Pick method list 'de
fault'
112718: .May 6 10:52:20.741 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.20.1.2
5:1645,1646 is not responding.
112719: .May 6 10:52:20.741 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.20.1.
25:1645,1646 has returned.
112720: .May 6 10:52:31.663 UTC: AAA/BIND(00000047): Bind i/f
112721: .May 6 10:52:31.663 UTC: AAA/AUTHEN/19 (00000047): Pick method list 'de
fault'
This is a fresh log. Start of authentication to finish. Any ideas why its failing?
112924: .May 6 11:22:15.538 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3,
112925: .May 6 11:22:18.146 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/3,
changed state to up
112926: .May 6 11:22:32.315 UTC: AAA/BIND(0000004B): Bind i/f
112927: .May 6 11:22:32.315 UTC: AAA/AUTHEN/19 (0000004B): Pick method list 'de
fault'
112928: .May 6 11:23:03.345 UTC: AAA/BIND(0000004B): Bind i/f
112929: .May 6 11:23:03.345 UTC: AAA/AUTHEN/19 (0000004B): Pick method list 'de
fault'
112930: .May 6 11:23:24.619 UTC: %RADIUS-4-RADIUS_DEAD: RADIUS server 10.20.1.2
5:1812,1813 is not responding.
112931: .May 6 11:23:24.619 UTC: %RADIUS-4-RADIUS_ALIVE: RADIUS server 10.20.1.
25:1812,1813 has returned.
112932: .May 6 11:23:33.351 UTC: %SM-4-BADEVENT: Event 'authTimeout' is invalid
for the current state 'auth_aborting': dot1x_auth Gi0
-Traceback= B6D4C4 18F7B4 306584 304984 304F2C 8D9B24 8D00EC
112933: .May 6 11:23:35.406 UTC: AAA/BIND(0000004B): Bind i/f
112934: .May 6 11:23:35.406 UTC: AAA/AUTHEN/19 (0000004B): Pick method list 'de
fault'
112935: .May 6 11:24:06.428 UTC: AAA/BIND(0000004B): Bind i/f
112936: .May 6 11:24:06.428 UTC: AAA/AUTHEN/19 (0000004B): Pick method list 'de
fault'
112937: .May 6 11:24:38.481 UTC: AAA/BIND(0000004B): Bind i/f
112938: .May 6 11:24:38.481 UTC: AAA/AUTHEN/19 (0000004B): Pick method list 'de
fault'
