bgp prefix lists
glen.grant
When using bgp prefix lists to filter routes is there any way to do a "permit any" like in a ACL or is this a restriction using prefix lists ?
Edison Ortiz
The command
ip prefix-list test permit 0.0.0.0/0
is equivalent to
access-list 1 permit any
HTH,
__
Edison.
HI Glen, [Pls Rate all Informative POST]
In addition to Edison's POST,
Refer Link below on how to Permit updates for any network with a prefix-list:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801310cb.shtml#ipprefixlist
Pls RATE all Informative POST
Best Regards,
Guru Prasad R
Hi all,
Edison,please correct me if I'm wrong. what about ip prefix-list test permit 0.0.0.0/0 le 32.
It will check 0 bit.It doesn't matter whatever bits are.It don't care about how long of the subnet mask.
Hopes this helps
Thot
Thot,
That command will work as well.
__
Edison.
