Port channel 10g interfaces
jmp780718
Is possible to config Port channel over 10g fiber interfaces?.
Thanks.
Sent from Cisco Technical Support Android App
InayathUlla Sharieff
You can configure without any hesistance. There is no document as such which says you cannot configure on 10gig or 1 gig.
Inayath.
Leo Laohoo
Yes.   configure the same way.
Same limitations:  Maximum of 8 links of the same speed.
Inayath.
