2960s Stack Port shutdown
I have a single 2960s without stack module. The stack port has a status of down, however I'd like to disable it so that it does not generate a false alarm in my NMS. The documentation states that there should be a command "switch 1 stack port 1 disable" but the switch (running 15.0(2)SE2) doesn't seem to  be available. Is this a dcumentation bug or is the command not there at all?
Any hints are appreciated.
Mat
Leo Laohoo
The command exist.  You need to invoke this in ENABLE mode and not in configuration mode.
Besides, you reboot this switch and you need to enter the command again.
Leo Laohoo
Thanks Leo,
I have not seen your answer up to now. Weird idea to move that to enable mode. Must have been a party day in the programming section....
Mat
