Port-channel between an ASA and a switch not coming up
jmendonc
Hey,
I am trying to setup ASA clustering.
I need to setup port-channels between the ASA and the switch on both the inside and outside of the ASA.
The clustering works alright on the ASA. The master and the slave come up perfectly.
But when I add the port-channel configuration on the Master ASA, I get the following logs on the Switch.
%EC-5-CANNOT_BUNDLE2: Et0/3 is not compatible with Po10 and will be suspended (trunk mode of Et0/3 is dynamic, Po10 is access)
%EC-5-CANNOT_BUNDLE2: Et1/3 is not compatible with Po20 and will be suspended (trunk mode of Et1/3 is dynamic, Po20 is access)
Can you please tell me how do i fix this.
Joyal
Can you clear the config of your interfaces on the switch side and configure first you're interfaces like:
sw mode acc
sw access vlan 10
sw nonegotiate
channel-group 10 mode active
Finish by configuring your po10 as access vlan 10.
Finally no shut your interfaces and PO.
See if it works better.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
Can you share your config please because here it says the interface is in trunk mode whereas port-channel is in access mode.
Francesco
Hey, Following is the config.
SW
interface range e 1/1
switchport host
switchport access vlan 10
interface range e 0/2 , e 0/3
no shut
Interface port-channel 10
switchport mode access
interface range e 1/2
switchport host
switchport access vlan 20
interface range e 1/0, e 1/3
channel-group 20 mode active
no shut
Interface port-channel 20
!cluster link
interface range e 0/0, e 0/1
switchport host
switchport access vlan 100
ASA- 1
!bootstarp configuration
Interface e 0
no shut
cluster interface-mode spanned force
cluster group CCIESECv5
local-unit PRI
cluster-interface Ethernet0 ip 10.100.100.1 255.255.255.0
priority 1
key cisco123
enable noconfirm
!configuration on the master
Interface e 1
no shut
Interface e 3
no shut
Interface Port-channel 10
port-channel span-cluster
nameif Inside
security-level 100
ip address 10.11.11.10 255.255.255.0
no shut
Interface Port-channel 20
nameif Outside
security-level 0
ip address 192.1.20.10
no shut
ASA-2
Interface e 0
no shut
local-unit SEC
cluster-interface Ethernet0 ip 10.100.100.2 255.255.255.0
priority 10
key cisco123
enable noconfirm
sw mode acc
sw access vlan 10
sw nonegotiate
Francesco
switchport nonegotiate actually helped.
Thanks Francesco !
You're welcome!
Francesco
