Netflow on the Nexus 5000
c2jkeegan
I can't seem to find any information on the Nexus 5000 support of netflow. I assume that means it doesn't do netflow, but I just wanted to see if anyone could confirm one way or another.
Joe
2 Accepted Solutions
Edison Ortiz
Joe,
No support for NetFlow on N5k.
__
Edison.
Lucien Avramov
Level 10
Level 10
Joe, the actual hardware does not support netflow.
7 Replies 7
Edison Ortiz
Joe,
__
Edison.
mmacdonald70
Netflow is used for routed links. Since the 5k is a l2 switch I doubt that it supports netflow.
Lucien Avramov
Level 10
Level 10
Does the 5k Support netflow with a layer 3 daughter card?
Hi Steven,
No, even with L3 card it is not supported.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Hi all,
Is there a recommended architecture for N5k to extract Netflow data? For example N5k with NGA (Netflow Generating Appliance)
Thank you,
-igor
