Port-Channel between ASR1001X & 3560G Switch
lucas.shelton1
We have an ASR1001X on the edge of our network with a single gig interface going to a 3560 switch.  I need to add a second interface between the ASR and switch, but am having trouble getting the port-channel to come up.
Note:  I am testing this in VIRL
ASR Config:
interface GigabitEthernet2
no ip address
negotiation auto
channel-group 1 mode active
end
host-10-255-0-47#sh run int gi3
Building configuration...
Current configuration : 96 bytes
interface GigabitEthernet3
no ip address
negotiation auto
end
host-10-255-0-47#sh run int port-cha 1
Current configuration : 92 bytes
interface Port-channel1
ip address 192.168.1.1 255.255.255.252
no negotiation auto
end
Switch config:
Switch#sh run int gi0/1
Current configuration : 144 bytes
interface GigabitEthernet0/1
switchport mode trunk
negotiation auto
end
Switch#sh run int gi0/2
interface GigabitEthernet0/2
negotiation auto
end
Switch#sh run int port-cha 1
end
I've attached a simple diagram.
Any ideas?
Reza Sharifi
Are you trying to create a layer-3 Portchannel? if yes, the switch config is layer-2 (trunk) and no IP.
Try changing the config on the switch from trunk to access and also an IP on the Portchannel in the same subnet as the ASR and test again.
Yes, but the switch is just a pass through to the Palo Alto.  What I had to do was delete the "channel-group 1 mode active" on the ASR and change it to "channel-group 1".
Also, on the switch ports I had to remove "channel-group 1 mode active" and change it to "channel-group 1 mode on".  It now works.
Ok, I did not have a clear picture of what you are trying to do. So, layer-3 is between Palo Alto and the ASR.
Glad to know its all working.
