Port Channel between server and 2 different switches?
jason.williams
Here's what I'm trying to do.  We are having new storage servers installed that will be using NFS.  I'm being told that they need to have their connections port channeled.  Right now, the servers have connections to 2 different 3750s for HA.
Is it possible to configure a port channel between these 2 connections?
Thanks.
Jason
Gregory Snipes
Level 4
Level 4
Not unless you sack the 3750s together or move to a nexus platform.
Gregory Snipes
Level 4
Level 4
Leo Laohoo
Greg's right.  If these two 3750 are stacked, then this is fine.
I thought as much, but of course the vendor is telling me "they've done it at other clients", so I had to double check that I didn't miss something new.
Thank you for the quick resposes.
Jason
I know what I'm talking about because I've used stacked 2960S and 3750 to create an etherchannel across the switches in the same stack.
